Question about Dell Inspiron 1520 Motherboard
Microphone not detecting sound in sound recorder
when i plug in the microphone, noting happens and i think a window is supposed to automatically open giving me options but it doesnt and microphone wont work in sound recorder
please help asap!
    New Friend:
  • 98 Answers
1. Right click the sound icon in the system tray
2. Click "Adjust audio properties"
3. Go to the "Voice" tab at the top
4. Ensure that a device is selected for the section "Voice Recording"--ensure the appropriate device is seleted--most likely ti will just be one option --make sure it is selected
Posted on Dec 19, 2009
Testimonial: "excellent thank you soooo much! "
6ya staff
SOURCE:
Microphone is not working
Note that the microphone is not listed individually in Device Manager because it works through your sound card. Perform the steps in the following sections in order, and then test to determine if your issue is resolved after each section.
NOTE: The microphone should be selected as the recording device in the Volume Control tool(sndvol32.exe).
To verify this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type sndvol32.exe, and then click OK.
  3. Click Properties on the Options menu.
  4. In the Adjust volume for box, click Recording.
  5. Click OK.
  6. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording.
Check Your Hardware loadTOCNode(2, 'moreinformation'); If your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer.
Jul 23, 2011 | Sony VAIO VGN-NR310E/S Laptop
How to detect microphone in laptop
I think it would be better if we check that the built-in microphone is working on your machine.
Internal microphone
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to better capture sound with the microphone.
-Adjust the notebook PC screen to place the microphone in the best direction for receiving sound.
-Speak directly into the microphone. Avoid speaking away from the microphone.
-When using the internal microphone, choose an environment without background noise.
Testing the record function on the notebook PC
1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
2. Click Record (the red dot) and speak into the microphone.
3. When you are finished recording, click Stop (the gray rectangle).
4. To play back the recording, click Play (the gray arrow pointing to the right).
If happens that the recording with the microphone have no sound we have check the settings.
Checking microphone settings
1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .
2. A Volume Control or Master Volume window opens.
3. Click Options , and then Properties .
4. Select Recording , and make sure Microphone is selected.
5. Click OK . The Volume Control window should change to a Recording Gain Control window.
6. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
7. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step
Ensuring the correct recording device is selected
1. Access sound properties:
-In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
-In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
2. Click the Audio tab.
3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
5. Click OK .
6. Close the Sound and Multimedia Properties window and test the recording.
Feel free to reply if happens the steps I've told you is not working. Hope it helps.
AnEspera
May 03, 2011 | HP Pavilion dv4000 Notebook
I am using a logitech headset as well as a creative headset. when i am using it in my home PC the mic in headset is not working. i can hear songs an all from the headset but if i talk in it others cant...
it might be as simple as changing your line in device.
in windows xp go to
Start -> programs -> sounds and audio -> voice
and try and change your recording device to an Logitech device.
Mar 04, 2011 | Computers & Internet
Hello I bought a microphone Philips SBC MD 110,but I don't know to use it on my pc. Its recognized like a device but dthere is no sound.I have windowsm vista OS,please can someone tell me how can i conecct...
Hi, There is never any driver needed when connecting a microphone to your pc or laptop.
Simply connect the 3.5mm jack to the microphone input on the soundcard of your pc.
Check the settings in the volume control settings at:"Playback" when using the microphone during a live presentation etc."Recording" when making a sound recording or using VOIP like Skype, MSN etc.
Note: this may vary depending on your operating system..
hope it helps..
Feb 23, 2011 | Philips Audio Players & Recorders
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Cannot set up microphone on my acer aspire one d255
You don't specify what type of microphone you are using.
The following instructions apply to a microphone plugged into the normal mic/line in (red) jak-plug socket on most computers.
If you are using a USB microphone the process might be slightly different because the system has to actually recognise the microphone first. Most are plug and play so will automatically be detected after a few seconds but some do need drivers installing from the mic manufacturers disk
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 01, 2011 | Audio Players & Recorders
My speakers work but my mic does not. I cant see any hardware for my mic
  1. In the Open box, type sndvol32.exe, and then click OK.
  2. Click Properties on the Options menu.
  3. In the Adjust volume for box, click Recording.
  4. Click OK.
  5. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording. Check Your HardwareIf your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer. Sound Recorder
  1. Run the Sound Recorder tool: Windows 95Click Start, point to Programs, point to Accessories, point to Multimedia, and then click Sound Recorder. Windows 98Click Start, point to Programs, point to Accessories, point to Entertainment, and then click Sound Recorder.
  2. After Sound Recorder is running, click Record (the circle on the right side), and then speak into the microphone. If it is plugged into the correct jack, the line on the display should move up and down. If it does not move, sound is not making it through your microphone. If the line does move, press Stop, press Rewind, and then press Play to listen to your recording. If this works, but it does not work in your program, view the "Using the Microphone in Programs" section in this article.
  3. Still Cannot Record
If you cannot record a .wav file after you follow the steps in the previous section, there may be a problem with your microphone property settings. To check these settings:
  1. Double-click the Speaker icon on the taskbar, and then verify that the Microphone slider is at the top and that the Mute check box is not selected. If Mute is selected, click to clear the check box.
  2. Select Properties from the Options Menu. Select Recording and click OK. Verify that theSelected check box under Microphone is checked, and that the Microphone slider is at the top.
  3. Try recording a .wav file again.
Jan 19, 2011 | HP (400745-001) Sound Card
Microphone Detected but not recording/working
in Sound Property, on the play back and record box , select volume and slide the slider to the max.
Oct 21, 2009 | Logitech (980240-0403) Microphone
Microphone port not working
in advanced settings there would be options for microphone boost and something else...disable both...i dont know the reason why this happens but mic doesnt work with those options enabled....
Dec 05, 2007 | ASUS A8N-VM Motherboard
Dell Inspiron 1520  Motherboard Logo
212 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
