Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Need mac address - Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Posted by ken817 on
Anonymous
    New Friend:
  • 98 Answers
Finding the Xbox 360 MAC Address
1. Go to the System area of the Xbox Dashboard and select Network Settings.
2. Select Edit Settings.
3. Under Basic Settings, check to make sure the IP Settings is on Automatic.
4. Now go to Additional Settings, select Advanced Settings.
5. At the bottom of this screen you'll see a heading called Wired MAC Address.
Posted on Dec 19, 2009
How to change V800R006C02 SCUB mac-address on Huawei MA5683T/MA5680T?
You can change mac-address of SCUB on Huawei OLT MA5680T in following way:
1. First you have to login as root user
2. You will have to enter in diagnose mode with following commands:
huawei(config)#diagnose
huawei(diagnose)%
3. you have to check which mac address is currently in the system by command:
huawei(diagnose)% display sysman mac-address
Current MAC address of active mainboard: 0025-1c54-c45c
Default MAC address of active mainboard: 0025-1c54-d0763
4. Changing mac-address you can done with command:
huawei(diagnose)%sysman mac-address current 0025-1c54-c455
Command:
Modifying current MAC address may cause the conflict of MAC address, are you
sure?(y/n) [n]:y
5. Last step is to reboot board on which you have change mac-address or to reboot system. In this way new mac-address will be applied to the SCUB board
Aug 08, 2018 | Huawei Computers & Internet
Does the producer of my Sony Vaio has my Mac address?
The MAC address of the LAN or wireless card is unique address (like a house number in your street in your town, state and country).
If you have not taken recorded this MAC address then you cannot supply this info.
There are millions of MAC address and Sony most likely do not have this info. If you have registered this laptop with Sony they might have this info.
Apr 19, 2013 | Sony VAIO Computers & Internet
I am not sure if it is a case of mac filtering. I recently got my iPad2 and it sees the dlink signal but "failed to join". I did not have a problem with the laptop and notebook with windows 7....
It could be, you need to check the D-Link's wireless settings and see if MAC address filtering has been enabled. If so then you need to add the IPad2 wireless card MAC address to the list of MAC address in the D-Link's MAC address table.
If MAC address filtering has not been enables then the D-Link's SSID and encryption (WEP or WPA or WPA2) settings need to be entered in the iPad2 wireless settings.
Have a look at the wireless settings in the laptop and notebook, these should be the same and you can apply these settings to the iPad2.
Apr 12, 2011 | Computers & Internet
How do i find out what my mac and ip addresses are?
Windows XP
  • The host name is your computer's name
  • Click the Start icon
  • Click Control Panel
  • Select Classic View
  • Click Network Connections
  • Right click on the connection you are trying to find the MAC address for and select Properties - you will have a separate MAC address for your wireless card and your Ethernet (LAN) card. Make sure you use the correct one.
  • Hover your mouse over the text box underneath connect using. Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your computer on AU network you will need to register this MAC address
Apple Mac OS X (Tiger)
Information Services does not provide support for the use of Apple Macs. However you may find the following instructions useful if you wish to use your Apple Mac on our network
  • From the Apple in the upper left hand corner choose System Preferences
  • Click on the Network icon
  • From the Show menu Select Airport (for Wireless) or Built in Ethernet (for Wired)
    • For the Built in Ethernet (for Wired) the MAC address will be at the top of the Ethernet tab as the Ethernet ID.
      The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
    • For the Airport (for Wireless) the MAC address will be at the top of the AirPort tab as the AirPort ID (or on the TCP/IP tab, again as the AirPort ID ). The MAC address is the 12 character address e.g. 00:14:67:F0:56:A4
  • To find your Computer Name go back to System Preferences and click on Sharing , your computer's name should be in the computer name box at the top of this window.
Apple Mac OS X (Snow Leopard/Leopard)
  • Select Ethernet for Wired or Airport for Wireless
  • Click on the Advanced button
  • Click on the Ethernet tab
  • Your MAC address will be at the top of this window as your Ethernet ID . The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
Linux
  • In a privileged terminal session type: ifconfig
  • This will show you a list of the network adapters installed. The MAC address is referred to here as the HWaddr
  • If you have a wireless card you will see more then one MAC Address, make sure you register the right MAC address.
  • To pick out your wireless MAC address type: iwconfig - your Wired one will be the other one
Vista
  • Click Network and Sharing Center
  • Select Manage Network Connections from the list on the left hand side
  • Hover your mouse over the text box underneath connect using . Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
Windows 7
  • Select Network and Internet
  • Select Change Adapter Settings from the list on the left hand side
    You will have a separate icon for your wireless card; your Ethernet (LAN) card and your Virtual WiFi MiniPort adapter (if you have one), each with their own MAC address. Make sure you select the correct one.
Nokia mobile phones
  • On the home screen, enter *#MAC0WLAN# or *#62209526#
  • Your MAC address will appear as a popup and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your phone on AU network you will need to register this MAC address
http://whatismyipaddress.com/
You can use this link to find out your IP address
Good Luck
Dec 06, 2010 | Computers & Internet
(F5D6230-3) Wireless Router: i need to know how to change my mac address on my ...
In your browser's address bar, type 192.168.2.1.
By default, leave the password blank.
On the Belkin setup page, go to Internet WAN.Then go to MAC address. You may close your computer's MAC address or type a specific WAN MAC address, if required by your ISP.
I hope this helps!
May 16, 2010 | Belkin (F5D6230-3) Wireless Router
How to change mac address?
Every Ethernet card has a MAC address burned-in at the factory. At times, you may want to change this MAC address to one of your own choosing.
The procedures to change a MAC address are specific to each operating system.
How to change a MAC address in Microsoft Windows Under Windows, the MAC address is stored in a registry key. To change a MAC address, find that key with `regedit` and change it. Of course, Microsoft keeps moving the location of the key around!
Windows XP adds an option to change the MAC address on some network cards under the Advanced tab in the network adapter's Properties menu.
A much easier and more reliable method to change a MAC address under Windows is to use a software utility program designed to do this for you.
Macshift is a free utility that you can use to spoof your MAC address under Microsoft Windows.
How to change a MAC address in MacOS Instructions for changing the MAC address on a Macintosh can be found at MAC Spoofing on the Macintosh.
How to change a MAC address in FreeBSD In FreeBSD, you can change your MAC address with the `ifconfig <interface> link <address>` command.
How to change a MAC address in Linux Under Linux, you can change your MAC address with `ifconfig <interface> hw <class> <address>`, or you can use the GNU MAC Changer.
How to change a MAC address in Solaris In Solaris, you can change the MAC address with the `ifconfig <interface> <ether> <address>` command.
How to change a MAC address in OpenBSD OpenBSD does not, by default, allow you to change the MAC address. It is possible to change the MAC address under OpenBSD with sea.c.
How to change a MAC address in HP-UX Under HP-UX, you can change the MAC address in SAM by selecting Networking and Communications, then selecting the interface, then Action, Modify, Advanced Options. HP-UX refers to the MAC address as the "station address".
Changing a MAC Address in Hardware Speed Demon Adapters sells network cards which give you the ability to change the MAC address stored in their EERPROM.
This can give you the ability to change your MAC address under any operating system that supports either the PCI bus or PCMCIA Type II cards.
Feb 12, 2010 | Linksys WAG200G Router
I have the same problem too
Try this procedure:
To Spoof a MAC Address
  1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records.
  2. Disconnect other computers from the router.
  3. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.)
  4. In an Internet browser type the address 192.168.0.1.
  5. Type admin for the username, password for the password, and click OK.
  6. Go to the Basic Settings > Router Mac Address.
  7. Select Use Computer MAC Address.
  8. Click Apply. This automatically gives the router the computer's MAC address.
  9. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Jun 06, 2009 | NetGear DG834G Router
Number of mac address (waN)
It should be on a label on the bottom, listed as MAC, HW, or HW Address.
If not, go into SETUP, WAN, MAC ADDRESS and it should show what your MAC Address is.
It will be a series of 12 hex numbers, either all together or separated like 12-34-56-78-9a-bc
Feb 22, 2009 | Gateway Cable/DSL Router - 4Port [ Belkin...
MAC address
Why do you want to clone the router's MAC address?
If you want the router's MAC address, go to the Admin (I believe it is) page.
That button is for cloning your Desktop or Laptop computer's MAC address, and unless you are being instructed to, there is no need to.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
209 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
