IBM ThinkPad 760 EL Notebook Logo
Posted on Dec 19, 2009
Ibm thinkpad 9547 wl4 will not boot
When I power up the screen shows 065152 KB ok then 161 underneath
after a while there is a sound like a siren then a box appears on the screen telling me to send computer back to a previous owner
computer was working ok, has been idle for over a year
what is the problem please
francis_nice
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 19, 2010
francis_nice
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
263
Points
Change the hard disk drive. Maybe this computer belongs to somebody else. If could be a hot computer, or just a program written by the previous owner who sold the computer without deleting it.
3helpful
Error showing on boot
The 161 error means the BIOS battery is dead (flat).
The 163 error means the Date and Time is not updating.
The BIOS battery needs replacing and the BIOS settings need to be configured (ie the date & time)
1helpful
2answers
Starting ibm thinkpad
Errors 161 and 163 mean the time and date are not set in the CMOS. This typically means the CMOS backup battery is dead / going dead.
2helpful
2answers
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
2answers
Boot sequence
161 and 163 error means you have to change your CMOS battery. open the laptop, change the cmos battery and you should be able to set the date and time.
after which you can access the bios by pressing F1 upon boot up and change the boot sequence after that
Replaced cmos battery
Try this:
Press and hold F1; then power on the computer. Hold
F1 until the “Easy-Setup” menu appears.
If you have set a password, the “Easy-Setup” menu appears
after you enter the password.
Plagiarized from:
http://www.wimsbios.com/phpBB2/topic9023.html
IBM Thinkpad R40e sometimes not booting ....
yes hit fn key again ok on kb itself that togles between #s and letters ok thx nick
IBM Thinkpad 600E 2645 not boots
Format the harddrive and install an Operating System of your choice.
Good Luck.
PS: You can probably disable that memory check in your BIOS to speed up your boot time as it is not necessary.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
