Question about Acer AL1706AB LCD Monitor
My web pages are to bright/ white.how do I fix this I would love to be able to see all the images. The background is white which blends with any light colors.
Posted by trevionrooks on
Laxman Bisht
  • 662 Answers
You can try to reset the monitor settings. Press the Menu button on the monitor and select and select Auto image adjust or reset option. This should bring back the colors or you can manually adjust the RGB (Red Green Blue) color bar from the menu.
Hope you find this information helpful.
Thank you for choosing Fixya
Posted on Dec 19, 2009
Tip
Images on the internet
When you create images for internet, you may be tempted to use a <b>transparent GIF</b>, if a web page background, however, sections of the image. Unfortunately, this usually leads to a terrible image quality. It is<br /> just put a picture in the background is the same color as the web page and save it as a JPEG file.
on Feb 22, 2011 | Computers & Internet
Black background when scanning in greyscale
There is an option to set the brightness/contrast in the first page of Capturperfect. Select automatic if you cannot manually set it.
S. Mohan
Mar 29, 2012 | Canon DR-9080C Path-Through Scanner
I am running two monitors; a Dell and an HP vp17. The Dell's color looks bright and clear. I am currently using it as my default or number 1 monitor. The HP colors are dull and the photo I am using on...
You will just basically have to go through the menu settings on the monitor and adjust the color,contrast, and brightness. No two brand of monitors are going to be the same. Even different models of the same brand will very.
Jan 24, 2011 | HP vp17 Monitor
Screen returned from supplier background bright pink, how do I change to white background.
To check if the video card or the Sharp LCD monitor is faulty, connect a different monitor to the computer. If this monitor displays a normal image then the video card is OK and the Sharp LCD monitor's back-light is faulty. Send it back to the supplier to have it fixed (they should not have reurned it to you in this condition).
If the other monitor also displays a bright pink background then the video card is faulty and needs to be replaced.
Nov 19, 2009 | Sharp Computers & Internet
Scanning produces 1/2 page yellow
uninstall the drivers in add remove programs and restart the computer then re install the drivers ignore the new hardware wizard when it pops up close it. then run the cd. it sounds like the driver got corrupted
Jul 18, 2009 | HP Photosmart 3310 All-In-One InkJet...
Printer printing very small
You are using Internet Explorer 7 and it automatically tries to fit the whole page in a sheet of paper.
Go to Page Setup and DISABLE Shrink To Fit
You might want to ENABLE the Background to print the lovely images
Nov 25, 2008 | Office Equipment & Supplies
Flash
i rally dont know, i personally always keep my flash on auto and keep the brightness auto or 50%. if this is the case, then i strongly recommend contacting Sony and asking them for a solution, or taking it down to the store you purchased it from and asking them to fix it or refund it!!!
hope this helps and sorry i couldn't help in much detail!!
keep in touch and tell us how its going
Dec 22, 2007 | Sony Cybershot S650 Digital Camera
Acer AL1706AB LCD Monitor Logo
138 people viewed this question
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
