My ipod nano will not recharge on anything except the computer. when i hook it up to my ihome, it just runs the battery down and does not charge while playing.
It sounds like it might be a battery issue. When it is hooked up the computer the USB is providing power to run the ipod and charge the battery. Check to see if the battery is good by testing it with a fluke meter if it is removable. And replace if bad. Also make sure you always release the device from the computer using the "safely remove hardware" function before disconnecting the ipod. This could also cause a problem.
<p>Your iPod nano to a device like the iHome to boost output
audio or video to a TV in your memory. The iHome also charge your phone as it
is docked. You need to take steps to ensure that your iPod will be able to
successfully dock the iHome. Once your iPod is well prepared, so you get the
most out of your drive for iHome. <br />
<p><br />
<p>1. Connect your iPod to your computer and launch iTunes. <br />
<p><br />
<p>2. Click "Help" from within iTunes, click
"Check for Updates". <br />
<p><br />
<p>3. Select "Yes" when asked if you want to download
and install updates. If no updates are available, disconnect the iPod. <br />
<p><br />
<p>4. IHome Connect your unit to an AC outlet. <br />
<p><br />
<p>5. Remove the protective layer of your iPod Nano, if
applicable. <br />
<p><br />
<p>6. Let the iPod Nano in the dock with the front facing you.
You will feel it snap into place. <br />
when I bought a ipod I researched them first. The lifetime of the batteries in the ipods and mp3 players are only about 2 to 3 yrs, depending on how many times you recharge.
