Question about Microsoft Xbox 360 Console
I connected my xbox to an HD TV and now I can't get the video to work on the older TVs. How do I get the video to work?
Posted by garrett_carn on
Anonymous
    New Friend:
  • 10 Answers
If you are using the A/V cable that comes with the pro or elite unit, the cables that have the red/blue/green in addition to the yellow/red/white, there is a switch on the connector that plugs into the console. This switch has two positions, TV and HDTV. make sure the switch is in the TV position.
Posted on Dec 22, 2009
My screen is broken but I want to play xbox can i hook up a older TV to the broken screen your TV and play xbox through the broken TV but using the screen of the old TV to play
You'd be much better off just hooking up to the older TV directly instead of trying to run an input on the broken TV and then direct the output through another TV.
You can always find cheap video adapters to connect to the older TV if needed.
Dec 27, 2015 | Video Game Consoles & Games
XBOX NOW PLAYS IN BLACK AND WHITE WITH OLDER TV DID WORK FINE AND DOES ON NEW HDTV ALL CABLES GOOD NOT SURE WHAT TO DO TO GET COLOR BACK
There is a switch that changes the video cable from SD( for use with older TV's without high definition connectivity) to HD (used for newer HD TV's with high definition.
If your older television is using a composite (yellow) connection for video, make sure the switch is in the SD position and NOT hd.
Mar 02, 2011 | Microsoft Xbox 360 Console
I am trying to connect XBOX360 HD to my tv and the video is not displaying in HD. it works on other tvs just this one. any solutions?
make sure you are using component or hdmi cables, anything less will not be HD. also check your video output settings on the Xbox and make sure its set for 1080 or 720
May 21, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Not working in hd with a hd lead connected but fine with composite lead connected
hi if you have the standard xbox360 and not the elite360 it will not work as the older standard xbox was not HD but the elite xbox is HD...hope that explains it for you
Apr 14, 2010 | Microsoft Xbox 360 Console
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Sep 12, 2009 | Microsoft Xbox 360 Console
No picture on tv screen when i turn on my 360 plz help
make sure the hd switch is not turned on on the video cable that connects to the xbox, it is a small black switch
Jun 28, 2009 | Microsoft Xbox 360 Console
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
Screen
hey man i understand your problum the reason why your xbox wont show up on both of your tvs is because 1. your tvs are no good or 2.you dont have the right connection to play your xbox on the hd tvs
Nov 03, 2008 | Microsoft Xbox 360 Console
XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Jan 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
