Question about Belkin F5D7130 And F5D7010 (Bundle) 802.11g/b (f5d7130/f5d7010)
Does anyone know where i can get the setup software for my belkin f5d7130 access point?
Posted by gaas12 on
  • Anonymous Mar 17, 2014
    how can i get this software because i,m trying to download from Google and i cant froom google
A Soveral
    President:
  • 566 Answers
You can download the manual and quick instalation guide for the F5D7130 Wireless Network Access Point
from Belkin. No software is needed nor is supplied with the access point.
If you bought the access point bundled with the network card F5D7010, then the disk that came with it would have the drivers for the card. You can get them from Belkin also. Click here
Posted on Dec 19, 2009
I can not get it to work at all. Is there a CD I need to get this set up? I have a Linksys wireless G router and the Belkin F5D7130 plugged in to it. But I have no range.
You don't need a CD - there is a web interface. First, download the user manual here.
I suspect your problem is the Linksys/Belkin combination. Linksys by default uses a subnet of 192.168.1.xxx while Belkin uses 192.168.2.xxx. With a subnet mask of 255.255.255.0 (the default for both), no communication would be possible between these two subnets. The "255" in each of those first three octets means they must match exactly.
Either move the Linksys to 192.168.2.xxx or the Belkin to 192.168.1.xxx (and keep the same subnet mask) OR you can change the subnet mask to a broader one (255.255.254.0) that allows the two different subnets to talk to each other. This subnet mask would have to be applied to both devices.
According to the manual, the default address of the Belkin is 192.168.2.254, which leads to your next problem - your PC probably can't connect to the Belkin device. Assuming your PC is configured for the Linksys subnet, the easiest way to communicate with the Belkin is to use a network cable directly linking your PC to the Belkin (may need to be a crossover cable) and manually set your PC's IP address to one in the same subnet as the Belkin, like for example 192.168.2.200 with a subnet mask of 255.255.255.0. Then you can open your web browser and point it to the Belkin default address, as outlined in the manual, and make whatever changes are required.
Feb 21, 2011 | Belkin F5D7130 And F5D7010 (Bundle)...
How do i reset the wpa key back to default
You can reset the Belkin back to the default settings by powering up the router and press and hold the RESET button on the back of the router for 7 secs.
The router's configuration URL is http://193.168.2.1
and the default password is blank (just press Enter)
Feb 04, 2010 | Belkin Wireless (F5D7130) 802.11g/b...
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
Browser display only half of the managed
ok maybe try rebooting the system to mange the router try going to do the same thing to help out trying to manage the display now
Jul 29, 2009 | Belkin F5D7130 And F5D7010 (Bundle)...
Connection
The setup page to configure Belkin routers is at http://192.168.2.1
If you have changed it, reset the modem to factory defaults by using a paper clip in the small reset hole.
Jul 04, 2008 | Belkin Wireless G (F5D7130) (F5D7130FR)...
Xbox 360 help
All devices on your network should be assigned an IP address. They need it to be identified on the network. You can try rebooting your router. The wireless on belkin routers can be a bit temperamental. Then try the 360 setup. If you are still coming up blanks, then check your router's DHCP server setting. Make sure that it is turned on. (It is the function that assigns the IP address.) My lat suggestion is to manually assign an address to the 360. Try this only if you are familiar with how IP addresses work. Hope this helps....
Aug 27, 2007 | Belkin Wireless (F5D7130) 802.11g/b...
Wireless Access Point Problem
only thing thats worth trying is hold the reset button on the router in for 10 secs. see if it makes any difference. you could install a new firmware but not likely to make much difference for that kinda fault.. John
Aug 09, 2006 | Belkin F5D7130 And F5D7010 (Bundle)...
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin F5D7130 And F5D7010 (Bundle) 802.11g/b (f5d7130/f5d7010) Logo
275 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
