Question about Sony Playstation 3 (PS3) Console
When I use the PS3 av cables I here a humming sound through the TV speakers. When using HDMI cable there is no humming sound. What would cause this humming?
  • Sony Expert
  • 311 Answers
Do the av cables pass by some power cables
they could be picking up some noise
also are the av cables the ones supplyed with the console or aftermarket cheap ones
Posted on Dec 19, 2009
6ya staff
SOURCE:
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Ps3 tuning
Hello!!
Try connecting the PS3 with the different cable ... i mean the problem may lies with cable ... So give atry once ..
Jan 03, 2008 | Televison & Video
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
A humming or buzzing noise through the tv speakers when hooked up with AV or componet cables!
This is a common problem with rca a/v aka red white and yellow cables.Time to buy new ones or go hdmi.But don't worry it's not your system.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
HDMI green screen
1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
The type of cable used and the inputs available on the TV or display monitor.
The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
Connecting to surround sound system
Hi to connect your ps3 to your tv all you would need is a hdmi to hdmi connector which would mean the sound would come straight out of your tv. The sound comes directly out of the hdmi cable. If you want to connect the ps3 to an external reciver you might want to get an AV reciver with HDMI inputs. This would connect to your tv and you can switch channels to different sources connected into the receiver, also they come with very good seperate speakers so you wouldnt have to use you telly speakers and you can connect your directv box into it aswell.
Alternatively you can connect the audio phono outputs from your AV multiout connector on your ps3 (the cable should be provided) to a seperate sound system with phono AUX inputs, these are found on most soundsystems but check with whoever your buying it from. But this means that you cant use the HDMI output of your PS3 for video just the AV multiout video signal (which is a bit rubbish, so I suggest the latter solution.
Hope this solves your problem
Rob
Nov 26, 2008 | Audio Players & Recorders
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
172 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
