During heating (outside temp. 2 deg C), outside
During heating operation (outside temp. 2 deg C), outside unit freezes and air conditioner stops working. What is best to do?
Posted by nino_dunat on
Anonymous
    New Friend:
Get the charge tested, check the sub-cooling across the outdoor coil.
Posted on Dec 19, 2009
Outside heat stops ac operation
clean coils seee if it makes a difference. all air-conditioners are designed by mfg. to run in a ambient temperture of 95 degrees. after that they lose effiency.
Feb 06, 2014 | Dometic Rooftop RV Air Conditioner
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
WATER COMING THROUG FRONT OF FUJITSU fan coil unit
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
Not sure the heat pump is producing enough heat
lower the fan speed to low and if you do not close your turns at 50 degrees Celsius then check the freon
Nov 04, 2011 | Heating & Cooling
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
Jan 02, 2011 | Heating & Cooling
REPLACED BOTH ELEMENTS GOT HOT WATER FOR 1 SHOW THEN IT GOT COOLER AND COOLER AND NOW ITS COLD ONLY?
Find a reputable HVAC contractor to do a room by room analysis with heat and cooling loads calculated and units sized and duct requirements and compare to what you have.
The air not being cold is not necessarily an indicator of anything malfunctioning. High efficiency units for instance don't produce cold air.
Since you have had someone look at it, the duct work may be collapsed which restricts air flow or uninsulated which warms up the supply air. Either one is a possibility. Any Cox Cable guys been stompin' around your attic lately? Wouldn't be the first time.
Usually, when the air coming out of the vents is not cold enuf it's because your freon level is low. Probably leaking, but they can usually recharge the freon and it will work for a while. Try another repair company and see if they can recheck the freon level.
We have a high efficiency unit and it produces cold air, so I don't know what previous poster is referring to. Air conditioners are supposed to blow cold air.
Sorry, to tell ya but it is normal if the outdoor temperatures are much below 45 degrees. Below 45 degrees there is little heat outdoors for the heat pump to grab to heat the home so it will run 24/7 and blow cool or cold air. Below 45 the temp of the air coming out the vent will decline and you will get no heat from the heat pump itself as you near freezing.
Your emergency heat or auxiliary heat is electric strip heat. But it only kicks in during normal operation if the temp in the house drops 3 degrees below the setting. (some tstats if can be 5 deg.) Otherwise the heat pump will blow cool or cold air the rest of the time if it is too cold out.
To prevent it from running all the time and blowing cold it is recommended if the temp outside is falling below 45 degrees you should just switch to the emergency heat setting, which shuts the pump outdoors off, and just heat with the electric.
But if there is no heat outside the heat pumps will blow cold. They are the cheapest and most efficient forms of heat but only as long as the outdoor temp is above that 45 deg..
I'm guessing that if you haven't experienced this you live in some place with moderate winter temperatures like in Northern Florida and rarely get very cold winter temps like the freezing you have seen there recently.
It will likely blow much warmer when the outdoor temp rises.
Aug 02, 2010 | Heating & Cooling
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Phkj048-1
If the outside temp. is lower than 32 deg. F it is normal for the outdoor unit to build up ice but not safe for the motor compressor. Because the safe outdoor temp. in heating is 5 to 64 deg. F but don't worry it has safety device to stop the operation.
Mar 18, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
