Bazooka ELA300.1 Car Audio Amplifier Logo
Question about Bazooka ELA300.1 Car Audio Amplifier
Heats up i have 2 4 ohm subs thunder 4000 and my ela300 heats up after a while
Posted by 7871israel on
Anonymous
  • 631 Answers
It's normal for amplifiers to heat up during normal operation. If you power up the amp and let it idle (no audio) for about 5 minutes and it remains cool, the heating (when listening at high volume) is likely perfectly normal.
let me know if you have any other questions.
Posted on Dec 19, 2009
How many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
1helpful
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
How do i wire a mtx 251d at a 2 ohm load
To wire up a 2 ohm load depends on the subs. You will either need 1 sub rated at 2 ohms or 2 subs at 4 ohms wired in parallel. This website will help.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41#results
You can also use 1 dual voice coil sub rated at 4 ohms wiring the same way you would the 2subs at 4 ohms. Good Luck
How do i wire up my mtx 15 5500 sub woofer dual voice coil any one know i have tried several ways
there are several ways, it all depends on the bass response you want, and with that, it also changes the ohms in the amp. i'm going to give you seval ways to hook them up. if you are running more than one just follow these steps per sub. the first one is if your sub is dual 2 ohm. Wiring Option #2
1_2ohmdvc_1ohm.gif Wiring Option #2
this is for dual 4 ohm coils
1_4ohmdvc_2ohm.gif Wiring Option #2
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
3helpful
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
2answers
Directed 1100d 2-channel amp
You will bridge the amp, and if the subs are all 8 ohm subs, you can probably wire them all in parallel, if they are all 4 ohm subs, you would wire then in series.
Top Bazooka Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
