Question about Technics SL-1200 Turntable
I have sl1200 mk2,the little lightstick dont light when its up?
Posted by unimobile on
Anonymous
    New Friend:
  • 135 Answers
Why is my Technics sl1200 mk2 platter movings back and forth when I hold it, light on the switch blinks and the lamp wont completely turn off, platter spins with no pitch control at all, what to do?
There would be no way to service your unit, if you live in remote area. There are too many ICs to just guess at one. Anything from a drive ic to a microprocessor(computer inside your technics). You need to be highly tehnical to repair this. Sorry.
Jun 13, 2014 | Technics SL-1200MK2 Turntable
My 1210 mk2 spins at crazy speed when turned on and both 33/45 buttons light up but dont do anything when pushed.
I have seen this problem many times.
Option 1:
If you are comfortable with soldering, try replacing the drive IC. This solves the problem 90% of the time. The part number is: AN6675 . This is a discontinued part so you may have to search around a bit, but you can usually find one of them on eBay for between $25 - $40. There are a few newer versions of the chip that are suggested as replacements, but most of them have been on back order for years and you could end up waiting forever. I'd stick with the OEM part number on eBay. Just be sure it is in stock before you buy.
Option 2:
If you are not comfortable with delicate soldering or want a fix that is easy and 100% sure to work, I suggest replacing the whole motor board. This may sound extreme but it's really not. These are discontinued as well, but are usually easy to find on eBay. I've purchased many of these for less than $115. That may seem expensive at first, but it is still way cheaper than the $300 - $400 price a repair shop will charge. Be sure to purchase from a reputable seller with good history and, be sure that it is in good working order. Some are not, so carefully check the description. Some may look a little different than yours due to minor changes over the years, but as long as it is listed as compatible with the MK2 series, it will work fine. This is the most fool proof option if you don't mind the price. Like I said before, it is super easy and always works.
If anyone else is having trouble with a Technics SL1200/1210 MK2, this link is a must have:
www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
I used this page again and again to save time identifying problems. Extremely useful. Good luck. EW
I’m happy to help further over the phone at https://www.6ya.com/expert/erik_149c4c1c216e42f2
Apr 13, 2014 | Technics SL-1200MK2 Turntable
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
Apr 28, 2013 | Technics SL-1200MK2 Turntable
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
I have two 1210s, a mk 2 and a mk 5. When I let go of a record on my mk 2 it seems to take longer to catch speed compared to my mk 5, and feels 'slack'. Any ideas what this is?
Being the older model, the chances are that the drive belt on the Mk2 turntable has got worn and shiny with use. It may also have stretched a bit. If you are using the tables for 'scratching', the fact that you are holding onto the turntable when the motor is running is placing a strain on the belt that it is not really designed for. I would recommend changing the belt - you can easily find spare belts for sale on the internet
Feb 02, 2011 | Technics SL-1210 Turntable
My powerswitch on the sl 1200 is pushed in how do i pull iit out?
Basically you dont.
You will need to replace the power knob which comes complete with the brass rod that goes through the strobe housing. To do this you will need to remove the base of the deck - be carefull not to lose the spring and ballbearing.
http://cgi.ebay.co.uk/TECHNICS-POWER-KNOB-SL1200-SL1210-MK2-GENUINE-NEW-PART-/300442767389?cmd=ViewItem&pt=UK_AudioTVElectronics_HomeAudioHiFi_Turntables&hash=item45f3c8d01d
May 27, 2010 | Technics SL-1200MK2 Turntable
TECHNICS SL1200MK2 RPM Buttons getting stuck..
Ed try spraying some contact spray directly in to the Buttons,push one then the other you will feel them free up Please rate my performance ttech
Jul 21, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200 Turntable Logo
288 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
