Question about Canon Elura 65 Mini DV Digital Camcorder
I have a Canon Elura 65 mini DV camcorder. When I
I have a Canon Elura 65 mini DV camcorder. When I open the tape cartridge cover, the carrier mechanism flips out in order to insert the tape. However, when the tap cartridge cover is pushed back against the carrier and the carrier moves to its correct position, instead of the carrier then lowering the tape into the camera to engage the tape spindles, it sounds a beep and ejects (flips) the tape back to where it was when first instered. No matter what I do, it will not lower the tape. However, with no tape in the carrier, the carrier lowers down and seems to do what is should. I have tried different tapes to no avail. This problem started immediatately after I accidentally dropped the camcorder.
    New Friend:
I had this problem and I only ejected a cassette. I tried new and old cassettes. Same result as you experienced.
What I did and I again don't condone striking electronics as a means to repair them but, at the advice of another post and having tried everything I could think of, I stuck the bottom of the camcorder with the palm of my hand several times and it worked. I don't know why it worked and it really shouldn't have but it did.
I think the real problem is a cleaning/lubrication and ultimately should see service by a local trusted shop. Try it I had nothing to lose and it worked for me.....
Posted on Sep 05, 2010
I am using an old, borrowed Canon NTSC Elura 100 camcorder with a Mini DV 60 tape. I do not have the original Picture Package software or the manual, and I am trying to transfer onto my computer, which...
You can download the manual, software, and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/elura_100
Dec 12, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 65 Camcorder USB input?
I tried to look over the camera for 20 minues and could not find any slot to put the USB cable in. I looked over the camera just one last time before giving up and and i found a little pull tab on the front of the camera. I pulled the tab and it opened showing a circular insert (for hookup to a TV) and a USB slot!
Sep 07, 2009 | Canon Elura 65 Mini DV Digital Camcorder
Tape deck won't open
Hello.
1. Completely remove battery and then restore it and try.
2. If you here sound of engine when camera wants to open door but can`t shake door by hand.
If problem persist you need to open it inside and clean it.
Sep 07, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 65 Camcorder Refuses to Load Mini DV Tape
Try a different tape in case the take up isn't working in the previous tape.
Clean the tape heads with a tape cleaner in case there is buildup on the pinch rollers causing the tape to jam or slip.
If those solutions don't work, you should take it into a repair shop to have a closeup view as to what the problem is unless you see something obvious like a spring broken or loose or a bent piece or foriegn objects in the deck.
Aug 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Cant put tape in camcorder
Then remove the tape and check it in another camcorder.....
............. Very simple.
If the tape works fine in another camcorder then throw this camcorder. Let me know the location where you will through it.
May 07, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 65 Mini DV Digital Camcorder Logo
271 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
