My sony KP-65WS500 has a bad red picture tube. So I followed the earlier post to turn down voltage and the red tube now works. But after its been on for about 4 or 5min the red fads alittle from the picture. Its not a big problem I was just wondering is this still the picture tube or could it be the bulb. The red also ficklers very slighty every now and then.
It was probably my post--SD TECH--you may want to tweek the red screen a little up or down--if it still acts up it is the picture tube--
The adjustment procedure is only meant to help and not cure the problem--try to get it as good as you can and live with it.
I have been involved with replacing those tubes and it is no picnic--you remove one--send it out for rebuild and put it back and do major adjustments--usual cost for rebuild is near 300 JUST FOR THE TUBE--real problem is that sooner or later the two other tubes will start to act up.
I composed those instructions to try to give people an option--to buy them some time--the picture tube is what some call a bulb--one in the same thing.
Lots of these sets had all three tubes changed when under warranty--what really happened is Sony put the wrong tubes in the sets to begin with.
My best advice is adjust it as best you can and when it goes replace the set.
Regards, SD TECH
Testimonial: "This help me greatly. In fixing the problem and gathering knowlege abot my set."
Well this helped me alot i will still look into fixing my set since a new equilevent will cost 1,100+.
