Question about Canon PowerShot A80 Digital Camera
Viewfinder shows blurred images
Viewfinder/lcd
shows blurred images when trying to shoot any type of picture
  • bugme585 Dec 20, 2009
    Thanks so much for this! I really appreciate it...just wish I'd found it sooner so I'd have my camera for Christmas!
  • Canon Master
  • 4,738 Answers
First, rotate the mode selector dial to "Auto", then check to ensure that you're not in macro mode. Also make sure that your lens is clean and there are no smudge marks.
If you've done all the above, and you're still getting blurred images, this then might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on Dec 20, 2009
6ya staff
SOURCE:
D80 with nikkor 18-200, no picture
raatl, You mean the LCD on the back of the camera right?  The image that shows up (playback) can have the duration changed in the menu settings, it may have been turned off which is a choice as well that mode (not having the LCD on) extends shooting time which used to be a problem with the earl D70 and the earlier battery type.  The D80 doesn't have that issue, try experimenting with how much time you really need to have the display on, if you shoot and like to show the image to people set it longer or just hit the playback a couple of times as you are showing people.
randy320sgi
Dec 20, 2008 | Nikon D80 Digital Camera with 18-135mm...
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot S1 IS Watercolors
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 27, 2008 | Canon PowerShot S2 IS Digital Camera
I see nothing in the Viewfinder...
The camera has a mirror lock up feature for cleaning the CCD sensor. You may have engaged it. Check your manual about this function
Dec 27, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Blur image in viewfinder and LCD display
Dec 23, 2007 | Canon PowerShot S1 IS Digital Camera
Blurred and distorted view of the subject
Its possible that there is a CCD issue with your camera. I've been reading more and more people are having CCD issues with the S1-IS. The CCD is the part of the camera that captures the image, and usually they distort or do some funky things with the pictures. Its entirely possible they would knock something out of focus.
Nov 13, 2007 | Canon PowerShot S1 IS Digital Camera
In camera mode, screen shows a blend of image and digital spectrum analyzer bars blurring the image
the ony way is to get the CCD replaced with a new one. Contact NIKON for free replacement as this comes under manufacturing defect.
Aug 16, 2006 | Nikon Coolpix 5700 Digital Camera
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Canon PowerShot A80 Digital Camera Logo
275 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
