Be sure it is wired for high or low voltage. In US this would be 110v or 220v I'm not fimallar with this one but most will wire to fit the voltage going to the pump. If it can be wited up or down it will have come from the factory wired 220v so you don't burn it up if wired wrong. As you say your running this on a above ground pool and they are usually wired for 110v.Also be sure you give enough time for the salt to mix as a lot of units won't run if the leavels aren't right. Good luck and I hope I have helped.
Testimonial: "Thanks for your help I will check all you have told me today. thanks again :o)"
