Question about Pasquini Livia 90 Espresso Machine
I have an early model Livia 90 (without pressure gauge on the front). When I open the steam knob, there is high pressure steam for about 1/10 second, then only a little dribble of water and no pressure. If I close it again and wait for about 1-2 minutes, then open it again, I get a good amount of steam long enough to froth my milk. I don't know whether the steam pressure is supposed to stay constant, but mine drops after about 15-20 seconds.......still has enough to finish the job, but much more in the very beginning. I suspect a valve is sticking when I initially turn the steam on, but I would like to know how to test this, and possibly locate the part and clean it if possible.
    President:
  • 1,618 Answers
The vent valve is the problem it is stuck in the open position. If you remove the top panel you will find the valve.
Posted on Dec 19, 2009
6ya staff
SOURCE:
I have an older Pasquini Livia purchased in the early 90s. It continues to heat up and then the relief valve goes off. Is there a thermostat to replace?
Yes, remove the top panel on the right side is a p. stat with a microswitch on top, either that has to be replaced or the tube is blocked and it cannot read the steam pressure.
Nov 10, 2011 | Pasquini Livia 90 Espresso Machine
This Livia 90 has been working beautifully for the last 5 years. Suddenly, the water does not heat up. The needle on the temperature gage reaches the point just before the red marking and then gradually...
Hi
If you open the steam knob before you turn the machine on and it heats up normaly, you need to replace the vacuum breaker valve on top of the boiler. Its the 3/4 hex nut with the little brass pin in the center. If its is stuck closed when the machine is turned off, its holds pressure in the boiler, so when you turn the machine on again it starts to heat up but reaches pressure fast and turns the element off before it heats up all the way.
Apr 25, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
Turned machine on - it went up to temperature - then it sort of "exploded" spraying water and from all sides of the machine - tripped the outlet fuse - I turn the steam knob and let all the pressure out. ...
Hi
That is the pressure relief valve blowing, and it can be scary. the problem is the pressurestat is sticking. You just need to replace the pressurestat. that controls the pressure in the boiler. You can adjust the to any pressure but the correct pressure is the light should go out at 1.1 on the gauge but the pressure will continue to about 1.2 on the gauge. If it hits 1.4 the pressure relief will blow. This is really a safety precaution to prevent the boiler from exploding, so don't try adjusting the relief valve.
Sep 14, 2010 | Pasquini Livia 90 Espresso Machine
My husband removed the steam wand from our Pasquini Livia because I am running out of steam too soon and I thought the wand needed to be tightened. Now we need to know exactly how the springs go back when...
There should be a brass disk also. The spring goes in first, then the brass disk with the curved side down, then the wand, and then the nut.
Low steam pressure, could be a sign of scale build up, or the heater is getting covered with sediment. The heating element is on the bottom of the boiler on a Pasquini. Also check you pressure gauge. It should b shutting off at 1.1bar of pressure. If it is lower that could be another cause of low pressure. It can be turned up by the pressurestat.
Aug 24, 2010 | Pasquini Livia 90 Espresso Machine
The machine does not produce water and makes loud ticking noise- pressure gauge spikes and release valve blows. What do you think is causing that-
Hi
That sounds like a couple of problems. For one the pressurestat is sticking and causing the pressure relief valve to release steam pressure. The second one is your probes are getting scaled and causing eratic water level senseing. They need to be cleaned. Replace the pressurestat first.
Jun 15, 2010 | Pasquini Livia 90 Espresso Machine
Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Oct 03, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Tooo much pressure
If you remove the top panel on the machine there is a pressure stat on the right side, with 2 wire connections going to it. That P.stat could be damaged and needs to be replaced, or the pipe to the P.stat is clogged and it cannot read the boiler pressure.
May 13, 2009 | Pasquini Livia 90 Espresso Machine
Livia 90 - Power on no pressure
When you say no pressure do you mean steam pressure or water pressure?
If it is steam pressure the machine is not heating up, then the elements could be damaged, disconnect the machine from power open top 4 screws on the top panel, you will see the boiler and element(middle of the boiler with 1 wire on each of the terminals) disconnect both of the terminals and check for resistance between the terminals, if you get a reading then the element is fine.
The bottom level sensor is not reading the water level and told the machine to not heat(stainless steel probe sits on top of the boiler there are 2 of them one checks the min water level and other checks the max water level, disconnect one of them and using ohms meter check reading from the stainless steel level to the top of the boiler, if there is a reading connect and then check the other one using the same method. If there is no reading on any one of those they might be covered with scale buildup or there is no water in boiler.
The machine cannot read the water reservoir(screw with ground connection on water tank).
There is also the Pressure stat(black box which sits on top front right of the machine with 2 electrical wires going to it), remove wires and check with ohms meter.
Mar 27, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
254 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Charles Tidwell
Terry
Terry
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
