Washer fills with water then runs thru the cylce and then the water drains but the drum is not turning. Is there a locking mechanism on the drum unit?
There are two potential problems. firstis te belt to the drum drive pully from th moter. this is the easiest. take off the back panel an seeif the belt is intact. if so run through a cycle and see if the motor spins or triesto spin. if not this is most likely thesuspect. one plug three screws and about100 dollarsfixes te motor. hope this helps.
