hi; you wan to hook up coaxial to rj12 ,if you you do that the wire of rj12 has not to exceed 3 meters cause camera signal (video) to become weak. Camera Video signal has to be fed only to coaxial cable, coaxial cable has an insulation to prevent interference. so if you want to hook up be sure put a shielded wire. thanks......hope this help.
It's called a reverse SMA. You can get a reverse SMA (f) to BNC (m) adapter for $5 and put any MURS antenna on it you wish. Here is a link to where I get mine at. Reliable people there.
LAN SMA-38-TGN ( SMA female - BNC male ) http://www.associatedradio.com/ about midway down the page under RF adapters.
I would be interested to know the model number of the camera. "Coax" jacks are usually only used for tuners. It is more possible that it is a BNC connection. If it truly is coax than they may have used the coax jack because an RCA style plug would come unplugged too easily while driving.
Just get an F (male or female depending on the connection) to RCA (female) adapter and an RCA cable and plug it into any composite (yellow) video input.
If it is BNC than get a BNC to RCA adapter.
http://www.cablesnmor.com/bnc-rca-adapter.html
Take the part into Radio Shack and they will have the right adapter.
Hi a simple CCTV one camera system is 1 pair of power wires (1 positive 1 negative) and 1 piece of coax cable with BNC connectors at both ends. (usually rg59 but RG6 is better)
Things to be aware of:
Cameras come in both 12v DC OR 24Vac configurations some are capable of both but most models available to consumers run on 12v most professionals choose 24v models.
simple adapters used to convert from regular coax screw type connectors to either an RCA connector or BNC connector are available at Radio shack. If you need more than 1 or 2 its cheaper to get them on ebay.
You can connect a BNC equipped camera to an input on your TV by using one of these adapters. *put an RCA connector on the end and plug it into one of the yellow video inputs on the TV.
This is pretty easy. Just buy the cables that have S-Video connection. Then plug the wii into the S-Video in on the left side of the monitor. Plug the Audio cables to your reciever or speaker in port on your sound system. Or, the other option is to Find or get a BNC to RCA adapter and use the RCA cable that came with the wii. My TV came with the BNC to RCA Adapter. The BNC location is on the left side of the tv, just above the S-Video connection. Then just change the input selector till you get the right input.
