SOURCE: How do i get the top off of my duravit toilet??
try to check if there is any screw on the side of pulling knob...try to pull it and chek around it...good luck!
best rgds Stefano
SOURCE: my duravit toilet keeps running
Sounds like the flapper valve on it. Let me know the model number and I can hok you up with more info on it
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
SOURCE: How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
SOURCE: maybe I'm an idiot but I don't know how to get the top off of my
If yours is like mine, which has the flush and half flush that make up a circle, do the following:
Press either the flush or half flush.
Lift up the other half. (It should come straight out)
Lift up the remaining half.
There should be a white plastic screw that you can then remove.
Hope this helps.
