Question about JVC KD-G421 CD Player
When i put a cd on it desplay's 00000 AO and wont play? radio is ok tho
Posted by ian_crombie on
1 Related Answer
Anonymous
SOURCE: CD,s will not play
Read the Manual on Page 2 or get it from:
http://de.jvc-service.net/public/document.cfm?prog=InstrBook.cfm&Model=KD-G321
Just make a reset with a pen or something else.
This should solve the problem.
Best regards
Dirk
Posted on Jan 25, 2008
Why wont radio work after replacing battery?
by replacing the battery the anti-theft code requirement has been activated
check the radio forums and comments on this site as there are ways to recover the code
Jul 25, 2017 | 2001 Chrysler Town & Country
My pioneer car stereo DEH-P77MP won't play cd's anymore. the radio still works, but on the screen it says cd error AO or A0. i was wondering what problem this code relates to? hope you can help,...
This is a common error with these units when they get dusty from putting dirty disks inside the drive. Just go to your local staples and or walmart and get a 5 dollar disk player cleaning kit. It looks like a plain cd but has small fibers that come out of the bottom of the disc that clean the laser as it spins and tries to read it.
May 09, 2011 | Pioneer DEH-P77MP CD Player
I have a 2004 Chevy Malibu - CD player is reading CD-Changer ERROR. The screen lights up The radio will play but wont let me take out the cd's or anything. The dimmer to the left is also reacting to the...
My bros 2009 model had issues with the player too.. he bought some manual from a website somethng like reliable store i guess. manual was really cool, tho. was of help more than once
Oct 26, 2017 | 2004 Chevrolet Malibu
My radio wont play Cd's. Everytime I put in a cd,
Your CD player's lens is not working, meaning either if you can open it and change the lens or install a new stereo, see which solution is cheaper.( you can find stereos for around $35) . Good Luck
Feb 09, 2010 | 2001 Pontiac Grand Prix
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Cd change will not work
Power Antenna Wire hooked up as amp turn on. Switch the blue wires around.
Dec 21, 2008 | Sony XR-M510 Cassette Player
Error ao pioneer head unit
If the discs PHYSICALLY get stuck, then the mech is damaged. A local shop MAY be able to fix it, but it might be a better investment to just replace the radio.
Aug 04, 2008 | Pioneer DEH-P6800MP CD Player
Error Message AO
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Mar 09, 2008 | Pioneer DEH-1900MP CD Player
NO CD
Ok im not to familiar about this head unit but some have a little hole where you can use a paperclip to reset it.. if you cant see one Take the negative terminal off the battery and keep it for for a minute or so...this will reset your deck and hopefully the deck will see it has a cd in it. Another thing you can try is to push a cd in like you normally would but when it starts to suck it pull it out and then it will think it loaded...that also worked for me in the past.
Mar 27, 2007 | Blaupunkt RPD-545 CD Player
JVC KD-G421 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
