Pioneer VSX-27TX Receiver Logo
Question about Pioneer VSX-27TX Receiver
RCA Model RT2500/RT2500R Audio/video Reciever Approx. 9 years old. Takes approx. 4-5 minutes to warm up. then works great. Seems to keep taking longer. Anything I can Do?
Posted by warrensworld on
Steve Allison
  • Pioneer Master
  • 5,569 Answers
It may be only some tired capacitors in the power supply; they can cause this kind of problem.
Parts are probably the lesser cost; you will need a tech with a little bit of gear to find the culprits.
Posted on Dec 18, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
1helpful
Sansui 7070 receiver Hum
Your filter capacitors in the power supply section are to blame and they need to be replaced.
Dryer model # ALE866SAW approx 9 years old ran great until tonight. Went to touch up load of whites (socks underwear etc) and get a sound from the back that sounds like an electric motor that just went on...
Yes it sounds like the motor is bad and that is very fixable, but what about the belts the guides and the wiring??? If this has been used hard ( more then 6-8 loads a week for 9 yrs then I would go new...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 09, 2010 • Dryers
13helpful
3answers
I have an RCA RT2500 audio-video surround sound receiver about 10 years old. For the second time in its life, a power fluctuation has knocked it out of service. The standby light comes on, but no power to...
Hold down the power button and unplug the unit. Now release the power button. Plug the unit back into the wall. Now press the button. The system should power up.
1helpful
No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
1helpful
Video flashes off and on.
the tuner module is bad.
where the cable goes in in the back of the set,there is 2 modules on the main pc board and they are soldered in.
the smaller block is the IF module and it has broken grounds inside. it has to be removed from the main pc board and there is 7 pins or so.once the module is out,remove the tin covers and resolder the grounds around the perimeter.put the module back in.
i have fixed 100 of them
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Steve
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
