Possibly heater fault....if you set unit to, for example, a 40 degree wash, the machine will just keep washing unit it reaches selected temp, then drain and do the rinses. If the heater is open circuit then it will wash and wash and wash until the module times out because it is not getting there and continue to rinses, making the programs excessively long. (You may also find, if it has a display that it sit at 0.01 for a long time at the end of the cycle. Not sure of your model as you have not posted it, but if you go through the test below you can test the heater. 1. Put main dial to off 2. Press and hold start button whilst turning dial one click to left (easycare 30). 3. When display show 8.88 or two of the progress light come on, release the start button 4. Turn dial anticlockwise to 90 cotton (take the long way, NOT thru OFF or you'll have to start over) 5. Press start The tub will fill a little and if the heater is ok, after a few minutes you will hear it 'kettling', the drum does not turn during this test. If you have a meter that checks amp draw, if the heater is ok it should read around 9 amps. Hope this helps
Have you tried the rinse cycle in every wash cycle selection on the dial. Some times after using one particular dial setting all the time the contacts on the switch get corroded or burnt out, if the rinse cycle works in other settings on the dial then this is most likely the problem. You can then look up on line and order a new switch for the unit usually takes about two weeks to get in and is fairly easy to replace.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
check the internet for a manual for your washer most of the time you can down load them. Put in the name and model number and state you are looking for manual.
Some timer dials will not turn all the time they will sit for awhile then advance . If it don't move for a long time sounds like you have a bad timer motor. Some motors can be replaced and some you have to replace the complete timer.
It sounds like the pull-out switch, under the pull-out knob, is not working and may need replaced. Go to Repairclinic.com and type in what your washing macine is not doing and they will give you hints on what to do next. But, it sounds to me like that is what is wrong with your washing macine.
