Question about Motorola Walkie Talkie 2-Way Radio
I have a GP328 4channel hand held can it be reconfigured to be used as an ordinary uhf two way
Posted by ian_hawke1 on
eradiostore
  • Motorola Master
  • 1,664 Answers
It should be capable of being programmed to a "simplex" frequency where you can use the radio simply radio-to-radio. This is a dealer programmable style radio. You would need to visit your local Motorola dealer to have it programmed. As for whether it will do "ordinary UHF", the radio would have to be UHF. This style radio was produced in both VHF and UHF. Your dealer would be able to advise you on which one you have.
Best regards.
Posted on Dec 18, 2009
Testimonial: "cheers for that i will get it checked out"
I have a number of Portalk xls 3230 hand held radios from a number of years ago. Just bought 2 more. Can I use them together and how?
if they all operate on the same frequency there will be no problem
if there is take them to a radio repair shop, and have the frequence band adjusted to the base station frequency
Aug 09, 2016 | Kenwood ProTalk XLS TK-3230 Business Two...
What cause a hand held akg uhf ht 40 mic to have popping in it?
Hi Rose,
The microprocessor is sensing set points each time the desired temperature is reached to average your comfort settings.
Jul 06, 2014 | Heating & Cooling
What frequencies I can use vertex VX 400 U radio
Not sure what frequencies are allocated in India for UHF ham, but may i direct you to the following: join yahoo group specific to your radio Make/Model, there you can get info and you can download manuals, schematics and other goodies.
I'm sure, but not 100%, that ham bands around the world have similar allocations on 70 cm band UHF, but as I stated, not 100% sure.
Best regards,
Peter
Feb 05, 2013 | Radio Communications
W do I turn off squelch control on a digitech DC-1065 marine radio hand held 5 Watt
Hi David,
Before I try to give advice, I need more info.
I possess a Digitech DC1065 UHF 80 Channel CB hand held, so there seems to be some confusion here.
I live near Perth, Western Australia.
Firstly, How many channels does your radio have?
If the answer is 80, then what you have is a UHF CB, not a marine band radio.
Marine band is VHF with 87 Channels, in Australia that is, and the default channel is always 16.
Digitech are an Australian radio manufacturer, so you'll get great backup service.
If your radio is not defaulting to Ch16, then I am right about it being a UHF CB.
Therefore, it is useless for VHF anything, let alone Marine band.
I'm almost 100% sure this is a UHF CB in your possession.
Try this to prove me right please.
Reply to me with your Country and nearest city, I'll then be able to find a solution for you real quick, though I believe I already have.
Looking forward to your response.
Regards,
Peter
Dec 21, 2012 | Motorola Walkie Talkie 2-Way Radio
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
I Have a tv sony kv m1400, but i don't have the user manual,so i don't know how to tune the tv.
1. Press and hold down the [White Arrow Up] 'shift' button.
2. While held down press the UHF tuning button (symbol for button is ->).
3. Press + or - to tune up or down the UHF band as required, until the required station is reached.
4. Select a spare Channel Position.
5. Press [Arrow Up] & [UHF Tuning ->] buttons again to store and exit tuning.
You must use the remote control. No tuning is available on TV.
Feb 09, 2011 | Sony Televison & Video
No vhf or uhf channels
Not if it does not have digital tuner
Dec 30, 2009 | Casio 2.5" LCD Hand-Held Color TV...
All four hand held systems failed during a performance
Hi kb
That is an odd encounter, and most probably one of the R.F.I. kind. Radio Frequency Inference can be caused by many things. Sometimes it can be a nearby piece of equipment creating that much interference, that the mics could not operate. It may have been a spurious mobile radio transmitter as used with two way radio for the cops, ambo's, firies,or even a nearby Cab!! Some times faulty light dimmers can also spray RF.
To what ever end, the fact that 4 mics went down together is indicative of an external problem, and being radio mics, it would have been radio interference.
The only other thing to check is that they are UHF. there are many VHF mic systems still about, but these frequencies are now being used as part of the soon to be introduced digital TV transmission. Best check that they are UHF, The VHF type have actually been illegal for a number of years Hope this info has helped you understand your problem. I am happy to answer any questions you may have. Cheers
regards
robotek
Dec 17, 2008 | Sennheiser Evolution G2 100 Series UHF...
Radio Communications Logo
279 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
