Question about Proscan 32LB30QD 32 in. LCD TV
Wall mount screws don't fit in my proscan 32lb30qd
The screws from my peerless st640p wall mount for my proscan 32lb30qd don't fit. Can I just buy screws at a hardware store and use those or is this not the appropriate wall mount model for my tv?
Posted by jeffreybgoul on
Bud Martin
  • 11,361 Answers
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Posted on Dec 18, 2009
Why vertical lines on half of screen after moving Proscan 39" LED TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 14, 2014 | Proscan 32LB30QD 32 in. LCD TV
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
Need to know how large a hole to drill into wall for manifold to fit no instructions came with my faucet set
If you can't find any documentation, the manly(easy) way would be to buy a hole saw set, find the part of the faucet that goes through the wall, and select the closet fit possible of hole saw that will fit the part. It's okay if the hole's a little bigger than the pipe because the cover plate will probably cover it up, but please double check before drilling that the hole really will be covered by the coverplate.
Oct 23, 2009 | Peerless Industries Peerless Wall Mount...
Need to buy a peerless wall mount kitchen faucet P 99305 from :[email protected] need help!
Peerless happens to be a less than preferred brand. If you go to www.peerless.com, you will find the model type. Try it, you may be able to order it online. haven't seen it around.
good luck.
Oct 09, 2009 | Peerless Industries Peerless Wall Mount...
I just mounted my proscan on the wall and can't figues out how to take off the stand
You probably have this figured out by now, but here's how I resolved it:
There are two holes marked with arrows, just above the stand, near the bottom of the set. Remove those. Next, roughly in line but slightly wider are two more phillips head screws. Remove those as well. The stand should slide out easily. Do what you want with the screws, but in case you have a future need for the stand, I jusyt put them back in the holes they came from
Mar 06, 2009 | Proscan 32LB30QD 32 in. LCD TV
Wall Mount won't fit screw pattern (405mmx200mm
for $19.99 you can get an adapter.  Do a search for TV mount adapters 200x400 on amazon, or tiger direct, or the shopping site of your choice.
Feb 18, 2009 | Proscan 32LA25Q 32 in. LCD TV
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Proscan 32LB30QD 32 in. LCD TV Logo
837 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
