Question about Samsung WF203ANW Front Load Washer
Door wont lock
Samsung front loader door wont lock ds code
Posted by dairiqueen52 on
Anonymous
    New Friend:
Door won't lock & shows d5 code what do i need to fix it?
Posted on Jun 09, 2010
My ds 1400 front loader has the " door " code come on when l try to start a cycle . Any suggestions ?
Hello Jarrad,
I have same problem on my Samsung washing machine. I put some duct tape on the door hinge so the door it's stay fix and not moving freely. Also you can check the lock system.
Dec 24, 2017 | Washing Machines
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
I have a amana front loader washer and it was doing its norman cycle and stopped at 35 min left and wont do anything and the door was locked so I unplugged it for a hour went back and pluged it in makeing...
This is an error involving the door switch, it is actually DS not D5. The door may not be closed properly, try pushing it in. Or you may need a replacement door switch.
Jan 27, 2015 | Amana Washing Machines
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
Samsung washer machine error code dE
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Jul 14, 2011 | Samsung Washing Machines
Error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Jan 26, 2009 | Samsung WF337AA Front Load Washer
Samsung WF203ANW Front Load Washer Logo
1,854 people viewed this question
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
