Question about Miele DG155-1 Steam Oven Single
Miele steam oven keeps wanting to be descaled after descaling!
My Miele steam oven keeps wanting to be descaled, despite me having twice run the descale cycle, using Miele descale tablets. Because of this, I am unable to use the oven ...other than to run the descale cycle!
  • Anonymous Feb 22, 2010
    Not yet, but about to take it to a Miele service agent.
  • Anonymous Mar 13, 2014
    Hi, I have just got a new flat and it has a Miele DG4060 steam oven. It's the only oven. Now when I power it up I can twist the multi function knob to scroll through the options but when I press it to select the option nothing happens! Any thoughts? Is it easy to take this knob out and clean and check it? Can I get a new one from somewhere? I all help gratefully received
carlos pena
    New Friend:
Yiou have to enter in service mode. ' 1- turn oven to off position 2- open door 3- turn knob counter clock wise to defrost position 4- push 3 times tempeture button until #02 appears on screen 5- with the + button go to 67 6- close door and wait 5 minutes until it resets by itself. enjoy your oven once again.
Posted on Nov 16, 2011
Anonymous
    New Friend:
Ours does too. Did you ever get it fixed?
Posted on Feb 21, 2010
How do I enter the secret Programming mode on a Miele DG 6401 steam oven to perform a total software reset?
Press and hold the timer button (the bell picture), and whilst doing that press and hold the power button. Then let go of both at the same time. Then press the timer button 5 more times, but on the fifth time hold for a few seconds. Once in Programming mode play with the options to reset and restart descaling.
Apr 12, 2018 | Miele Ovens
Tip
Reset Miele steam oven - enter hidden programming mode
My Miele was stuck in a loop repeatedly asking for more water, and then I got it stuck in a descale loop. I called Miele to ask them how to 'reboot' the factory settings, but all they would suggest is me booking a visit from an engineer. Expensive and pointless.
However, I then managed to find a video of someone entering the hidden Programming Mode for another model, and the same button combination worked for me.
Press and hold the timer button (the one with a bell picture on it) and then press and hold the power button at the same time, and let go of both together at the same time.
Then press the timer button alone 5 more times, and on the 5th press, hold for a few seconds. From there I played around with a few options until I found one that reset and restarted the descaling. I've linked to the video where he enters Programming mode after 2 minute mark.
DG4082SS Steam oven
on Apr 13, 2018 | Miele Ovens
Miele DG6500 steam oven
Mine did the same thing. Unfortunately, I had to get Miele out to reprogram it. They said it was a "software" glitch and Miele are the only ones with the electronic program to access the software to fix it.
Sep 17, 2017 | Ovens
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Error code On Miele Steam oven - oO
o O means that the unit needs to be descaled. See your owners manual for the procedure. If the unit displays O - - o, the safety lock has been activated. Again, see your owner's manual.
Feb 01, 2010 | Miele DG155-1 Steam Oven Single
Miele steam ovens
A dedicated circuit is recommended. 208-240V 20A L1 L2 & Ground, Neutral not required.
Jan 30, 2010 | Miele DG155-1 Steam Oven Single
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
How do I descale a Miele steam oven?
Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
Hope this helps
Jan 31, 2009 | Miele DG155-1 Steam Oven Single
Ovens Logo
2,324 people viewed this question
Top Miele Ovens Experts
Paul Bade
john h
Richard C Cohen
Richard C Cohen
Are you a Miele Oven Expert? Answer questions, earn points and help others
