Question about Archos 5 MP3 Player
File system error: FAT is corrupted
When i turn on Archos this message shows. File system error: FAT is corrupted.
Posted by psubero7 on
Megasom
  • 699 Answers
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
Posted on Dec 20, 2009
My archos 605 wifi when turned on,says file system error FAT is corrupted.
Just Format the Player it would Fix the Issue! Its a Memory Issue!
Dec 29, 2011 | Archos 605 WiFi Digital Media Player
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
My archos 605 wifi media player when turned on,says fat is corrupted.what is te problem
Hard Drive Needs to be Formatted!!!!!! Just Plug in the device, Go to My Computer, Right Click on ur device and format it, But before doing this make sure you back up the data if there is anything because formatting the Player would erase the data on It!!!!
Dec 29, 2011 | Archos 605 Wifi Portable Multimedia Player
In Phone show error "memory card corrupted" &
1) Insert your card in the mmc reader.
2) Find the drive in which it is inserted from your pc.
3) Right click the selected drive and select FORMAT but NOT quick format.
4) Now, in the file system selection part, select the file system to be FAT and not FAT 32 or NTFS file system.
5) Start formatting.
Nov 03, 2011 | Nokia 7610
> FAT is corrupted
FAT === File Allocation Table
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK C: /F
Press Enter
When you're asked to allow "Check Disk" to run at the next restart of Windows, click YES.
Restart your computer.
The "Check Disk" will run -- it may automatically restart your computer as soon as it finishes "fixing" the corruption.
Oct 22, 2010 | Computers & Internet
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Apr 15, 2009 | Archos Internet Media Tablet MP3 Player
File system error FAT is corrupted
Hi
This is the best solution i found so far...
i have an Archos 5....i went to : TOOLS - SETTINGS - CUSTOMER ASSISTANCE - REPAIR and FORMATTING TOOLS - REPAIR SYSTEM - clear temporary system files and cache..! (At the repair system page, you will get all options like "Reset Settings;Format harddrive;Full reinitialization etc...So u can choose what suits you best, n ALAS! Your achos will be back to normal....
Cheerz..
Roscoe
Mar 16, 2009 | Archos 405 Digital Media Player
Archos 400 won't turn on (error code 3)
I hard tried the same thing to transfer a 6.7GB file to another computer.I had formated the drive as an NTFS drive. when i turned archos back on, it failed to turn on give me error code. but for some reason it asked me to do a recovery. I remember i had seen some recovery files in my archos device saved (zipped file packages). And when it was doing the recovery i noticed it was reading the zipped files for recovery purpose. After the recovery, i did not see the files anymore in the device. So if i do the same thing again (format as ntfs) i might not be able to recover it back again.
Mar 11, 2009 | Archos 404 Digital Media Player
I have a Archos 605 & I have put some music on it. I keep getting messages displayed saying File Corrupted on certain tracks. When I try & delete this track I get the message Error Accessing the...
I`m solved this problem
When playing MP3 press the i simbol on screen
to see info of the MP3 file , if you have file with 48 kHz not sure about bitrate convert this file to 44 kHz
and any bitrate you want and replase old file with new file
Strange this file (48 kHz 320 kb/s) playin whithout any problem when backlight is on
Jul 16, 2008 | Archos 605 WiFi Digital Media Player
Corrupt File System
Well i guess that either your file system is corrupt or your disk is formatted into a filesystem that it's not supported by the backup programs. I don't really know what filesystem is your disk formatted into but usually the FAT32 and FAT16 are the most failsafe file systems for Windows.
So copy/paste the data you don't want to loose and then go to
My computer -> right click on the drive icon -> format and then choose fat 32. Then try backing up your laptop again.
May 20, 2008 | Western Digital Passport WDXML800UE...
Archos 5 MP3 Player Logo
1,824 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
