Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up close.The lines change vertical positions when the picture changes.When i have the TV in freeze mode.....the frozen picture is clear and also the real time picture on the right of the display is also clear with no vertical lines.I was told that it maybe the display unit and its expensive to repair...Otherwise it works fine and has a great picture except for the vertical lines...any suggestion would be much appreciated!
  • 616 Answers
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Posted on Dec 18, 2009
6ya staff
SOURCE:
I have a Sony Bravia 52 inch HDTV that has a line down the middle of the picture in some shows, particularly when action is panning across a scene. Is this a common problem?
Check with a different CD or a different channel. Sometimes some,
secret codes are displayed to find the pirated CD. Any how check in different program channels. This is not TV problem.
If you have DVD try a similar action movies in CD and play to satisfy!
Aug 21, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a vertical line in the middle of my screen
Call for warenty repair,ur tuner board have problems.Or tries bring it back at were the store u buy it at.Return it exchange for another one.
Mar 23, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
We have a sony bravia tv after the tv has been on an hour or so a vertical green line appears periodically on he right side also shadows appear around images too. They replaced the whole pannel and the...
There is a board on the LCD panel towards the top of it that is called the T-Con board and is sometimes included with a new panel. If it is not then they had to transfer the old T-con to the new panel. If this is the case then most likely the T-con board needs to be replaced. The servicer will have to verify and order by model and serial number as there are usually different part numbers for the T-con board. Please take a few moments to rate my answer. Thanks...
Nov 23, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Oct 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
May 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line on left side of screen
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
I can't get rid of the information bar across the top of my TV
Press " i " (information) button on TV remote and on-screen display will disappear.
Dec 29, 2008 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
732 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
