Question about Motorola Mobility Q9m Smartphone
Volume is to low when you listen music - Motorola Mobility Q9m Smartphone
Posted by george_delar on
Jax Planet
  • 923 Answers
There are two volume controls. The main volume for the phone which you should already be familiar with. There is also volume control in Windows Media Player. Volume in WMP is usually increased by pressing up on the direction pad while WMP is open.
If this helps please vote for my solution.
Posted on Dec 18, 2009
  • Steve Walters
    Steve Walters Apr 28, 2013
    Have the same problem with my pantech c810 i`ve tried the volume up button a billion times but the volume is stuck at 30% which is too low to hear whats playing........
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Sound level should be plenty loud even with earphones. If you are listening to music on spotify, youtube etc. be aware that those programmes have their own volume controls so even if they are turned up full, the level will be low if your computer master level is low. You need to access the computer sound mixer and make sure all volumes/output levels are turned up.
Apr 02, 2016 | Computers & Internet
Volume
Hello john
Have you tryed reseting the device?
Il get you instructions in a moment if you havent.
May 07, 2008 | SanDisk Sansa e200 MP3 Player
Low volume
Karl,
Click the link below for troubleshooting sound and mic issues within windows.
Sound Problems in Microsoft Windows
http://dell.to/1cd4d8A
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 26, 2013 | Dell XPS Computers & Internet
No volume appeared in home screen but it plays the music
May be ur volume controller is on the problem that's why u still able to listen music some times low as well as high so solution is that replace the rubber chip by a new gud working conditions.
Aug 08, 2013 | Sony Walkman Video NWZS615F MP3 Player
How do I tune my KICKER 08ZX1000? I have the amp running to alpine type r 12 inchs at 2 ohms but I don't know where the bass boost , gain, and crossover knobs should be pointing or what one to turn up...
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Aug 20, 2011 | Kicker Car Audio & Video
The music volume is low
Depends what you're listening to. If the sound can be turned up in other locations in your computer, then the encoding of whatever music that you're listening to may just be low. Turn up your volume from both your master volume on your computer, and from the application from which you're playing the music.
Jun 04, 2011 | Computers & Internet
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
Low sound.
Are you aware that the volume can be adjusted while listening to the music on the upper right side of the mobile? or you can increase the equalizer and stereo widening. Thier locations? on the music player home click on more>setting>equalizer /stereo widening. Just adjust it the way you want. Enjoy!
Apr 20, 2009 | Sony Ericsson K550i Cellular Phone
Volume is stuck
i would load all of the music onto one single computer, then reset it and then if it deletes all of your music you will have it backed up.
Oct 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Volume
Dumb me. I should have read the manual first, instead of just glancing through it.
You just turn the thumbwheel to adjust the volume.
imjohn
May 06, 2008 | SanDisk Sansa e200 MP3 Player
Motorola Mobility Q9m Smartphone Logo
Top Motorola Mobility Computers & Internet Experts
Tom Chichester
Dream
sadiq rehan
sadiq rehan
Level 1 Expert
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
