Question about HP OfficeJet 7410 All-In-One InkJet Printer
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did originally.
Posted by nolan574 on
Nadeem Uddin
    Novelist:
  • 188 Answers
Hai
This is really very easy to change the settings of the printer which is printing in color to black and white.
Here is the weblink which has detailed settings with graphical view follow step one to change the settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00242764&cc=us&lc=en&dlc=en&product=391194
This should resolve the issue.
Posted on Jan 29, 2010
Anonymous
    New Friend:
  • 27 Answers
Go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Posted on Dec 18, 2009
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
[email protected]
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7110 won't print black and white w/o color cartridge. I never print in color; yet the machine will not print in just black and white without having a color cartridge with ink in it. Why would...
I've used HP Inkjet/Officejet printers for years. Many HP inkjet printers also use the color cartridges to some extent to create 'black' in slightly different shades, that can be un-noticeable to the eye.
To print using only black ink, try doing as follows:
When you click on 'Print' from your browser, the printer properties (or preferences) page opens.
You must first set the printer to not print in color (color is the default setting). Then you must set the printer to use 'black ink only' by using the 'advanced settings' as follows:
1. In most browsers there will be a box on the lower right of the printer properties page that says 'advanced'.
2. Click on that box to get the advanced settings page to open.
3. Once open, the feature you need to check is called 'print in grayscale'. (It is usually at the top of the list) It is set to 'off' by default. Just click on it and a menu box drops down and one of the choices is 'Black Ink Only'.
4. Click on that and then 'save' or 'apply' those settings.
Then your printer should be using black ink only.
You will probably have to set that each time you want to start a new printing job, as the default settings on these printers are tilted toward using the color cartridges in order to sell you more colored ink.
Also, if you are using Windows 10 and the 'Edge Browser' that comes with it, you cannot get to the 'grayscale' option. So either use a 3rd party browser, or use good old Internet Explorer, (which is still included in Windows 10) to open and get to the page you are trying to print.
I hope this helps. If not, go to HP.com and type in the model number of your printer and then do a search from there for detailed instructions for your printer model (which might be slightly different than what I have shared here.
Apr 28, 2017 | HP OfficeJet 7110 All-In-One Thermal...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Won't print in color
Is the color cartridge new and do you know how to check the gauge in your control panel for the ink levels?
Jun 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Won't color print
If this is a heavy use machine, then it probably needs to be completely disassembled and cleaned from the inside out. A good cleaning cures most of what ails and inkjet printer.
Inkworks
Feb 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
Feb 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer not printing
if you purchased generic replacement cartridges,you may have gotton bad cartridge(this happens alot),if not you're print head may be clogged,if that's the case you will need to bring it to a repair shop to be cleaned,very messy you would not want to try to clean
Sep 16, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
311 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
