Question about LG 42LH40 LCD TV
My lg tv (model number 42LH40) won't turn on. it is plugged in and the power outlet works fine. the red/green indicator light is not on, it seems as though there is no power to the tv at all.
    New Friend:
There might be an off on switch under the lower right hand corner of the set. (feel for it) and switch it.
Posted on Feb 13, 2010
  • 11,361 Answers
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Posted on Dec 18, 2009
6ya staff
SOURCE:
Panasonic TV TH-L37S25A no power no red light, when plugged in and turned on at wall.
I'm guessing your power board went out and will need replacing. If you have the model number correct your going to have a hard time finding that board, I looked and couldn't find one anywhere, couldn't find that model listed
Feb 09, 2018 | Panasonic Televison & Video
I have a sapphire subwoofer model PS 3 b. When
theres no input signal. the green indicates only when it detects incoming. check your amplifier.
Oct 03, 2014 | Televison & Video
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
ELCHW402 won't turn on
An internal relay may have failed.
Dec 08, 2017 | Element ELCHW402 40 in. LCD HDTV
The On/off button of my LG LCD does not turn on the tv and the red/green light of the power indicator doesn't light up, but when plugging in the power cable to the outlet the on/off button light is...
your TV has a power supply issue or a logic fault.
Don't try and fix this yourself as the power supplies in these TV sets are extremely dangerous !!
These TV's can only be fixed to board level which means this repair may get expensive.
My advice would be to take the TV to a professional or have them call to your home to check it out..
Jan 13, 2011 | LG Televison & Video
I have a new LG 32 LD450 TV. When the set is on, there is a green light in lower right. when set is off there is a red light in lower right. should this red light be there all the time, even when set if...
The red light means it's on standby mode but if you wish to turn off the red light you can just go to menu >option>power then choose standby light off.
Jan 08, 2011 | LG 42LH40 LCD TV
No indicator light or power
Please look at these two links; I suspect your problem is related:
http://www.fixya.com/support/t4592070-tv_no_power_will_not_switch
http://www.fixya.com/support/t4596948-tv_stopped_working_bit_fizzing
This model seems to be having a ton of power supply problems.
Apr 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Wont turn on
lg has a problem with that model--usually bad electrolytic caps(most of the time the tops of the bad caps are swollen)if you take apart the unit you should see them problable in the power supply--if you dont think you can change them--contact a local shop-ask 4 price 2 change them or u can go to shopjimmy.com--enter model number--scroll down til u find power supply--if not in stock write down part number--google part number to find one
Sep 18, 2009 | LG 32LC2D Television
LG 42LH40 LCD TV Logo
1,165 people viewed this question
Ekse
RONALD CARTER JR
