Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
Cell phone blackberry trackball stopped working!
Blackberry trackball stopped working!
Anonymous
    New Friend:
Use a alcohol swab and gently rub it over the trackball. Rub it and roll the ball.. Eventually this cleaned the ball and it worked perfectly!!!!
Posted on Dec 21, 2009
steve perks
    New Friend:
Alcohol works well when its inside me, then feel good about tackling the problem and inherent design problems of dirty balls
Posted on Feb 14, 2013
Blackberry curve 8330 keyboard and trackball doesn't work
Your trackball and the keyboard seems not working. You may need a replacement for both parts.
Jun 17, 2017 | RIM BlackBerry? Curve 8330 Cellular Phone
I HAVE THE APP FOR TRACKBALL LIGHTS, HOW DO U ACTIVATE IT AND GET IT TO WORK?
The Blackberry Torch doesn't have a trackball. OIder Blackberry's used to have it. You won't be able to use the app on the Torch.
May 27, 2011 | RIM BlackBerry Torch Cell Phone
The blackberry scolling ball doesnot work
Your Trackball just needs to be cleaned. To learn how, Google the words, "How to clean Blackberry Trackball (type your phone model number here without the brackets).
There are several websites, to include video's on You Tube that will show you how to properly clean your phone's trackball.
Feb 05, 2011 | Cell Phones
Blackberry Bold trackball rolls perfectly but click doesnt work.
Your trackball is faulty and should be replaced, please contact a certified blackberry support personnel for repairs.
Regards
Mar 01, 2010 | RIM BlackBerry Bold 9000 Smartphone
You can get a new trackball from www.bbmedic.com They have them in different colors too.
Dec 17, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
May 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Trackball Is Brocken!
Good evening!
Trackballs are VERY easy to replace! You can take it to your cell phone provider but there is a good chance they will claim the phone is broken.
I would recommend searching on Amazon.com, Ebay, or just googling Blackberry Trackball replacement. They are inexpensive, range from $2 to $10 depending where you look and the quality of the trackball.
I personally have replaced my Blackberry's trackball with a new one off of Amazon. It is very easy to replace. You just need to be careful with handling the trackball due to they are very fragile.
Here is a bunch of replacements you can look into on Amazon:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=blackberry+trackball&x=0&y=0
Youtube even has a few videos on replacing the trackball.
Glad to help you out and good luck with your Blackberry!
Jan 16, 2009 | RIM BlackBerry 8700g Cellular Phone
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
172 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
