Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
I need a new high pressure hose for inside the gaggia synchrony logic, measures about 43cm. Where can I buy one?
Posted by davidmars386 on
ifr500
  • Gaggia Expert
  • 109 Answers
Contact Saeco in your country
Posted on Feb 25, 2010
I just got a new Gaggia Synchrony Logic RS from amazon and it only leaks water when we turn it on?
brand new --out of the box-- still covered by warranty --don't fix --contact your supplier and ask for a return of defective item and a refund or a new unit as replacement
Jul 28, 2016 | Gaggia Synchrony Logic RS
Gaggia synchrony logic making grinding noise
With these removable units, you must be very careful, the circular mechanism that does the running of the Y motion need to be properly alligned. You need to perhaps put the back of a knife in it and adjust until all the parts align, Then it must click in easily. If you have forced it in the clip will not release. you need to rattle it a little.
Sep 02, 2012 | Gaggia Syncrony Logic 74884 Espresso...
I have a Gaggia Digital Syncrony. The machine
Hi
You could have a micro switch in the doser that is going bad and needs to be replaced. They are a special micro switch that is very sensitive and can get stuck with a little coffee dust inside the switch.
Mar 10, 2010 | Gaggia Syncrony Compact Digital Espresso...
Where can I purchase a replacement dispenser shute for Gaggia Synchrony Logic Type SUP 020 Ser.#9005GA40015808? Many thanks.
Check the site at importika.com they have a list of repair areas any one of them will have a spout in stock.
Mar 10, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Jan 04, 2010 | Gaggia Syncrony Compact Coffee...
Need new gasket for boiler for syncrony logic
You can check with wholelattelove or servicesunlimited.
Oct 20, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
Gaggia Synchrony - we need a new boiler.
http://www.cafeparts.com/dynamicIndex.asp This site has parts.
Feb 16, 2009 | Gaggia Syncrony Espresso Machine
No coffee, only steam on gaggia synchrony
The solenoid valve is probably stuck (also called a three way valve). I wrote about how I fixed mine in another post. Here's a link. From there you'll find links to where you can buy a new solenoid if that's what you need. Good luck.
Nov 23, 2008 | Gaggia Classic Espresso Machine
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
