Contributor
- Posted on Jan 10, 2010
Re: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Damian, thanks for the advice. I'd also seen this on other postings and tried a couple of times with little success. When I finally bit the bullet and removed the base cover from the machine I discovered a pin-prick leak in the sump connecting pipe. So I did have a leak after all - although very small and no water on the floor! Replaced pipe and reset switch and have had no problems since. So the switch was doing what it's supposed to do. Cheers
