Question about Frigidaire Ovens
Oven will not light. it is a frigidaire model #
Oven will not light. it is a frigidaire model # fgf316bsa. electric igition element glows red but gas oven will not light
Posted by sdp804 on
Michael Masters
  • 6,784 Answers
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Posted on Dec 17, 2009
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Dose the oven have a pilot
Only if it's a gas oven. If it has electric elements at the bottom and top that glow red when it's on, then it's electric, and there won't be a pilot light.
Dec 24, 2010 | Ovens
Controls work fine , element glows red, but stove dorsnt light, huh.
Ok, I'm assuming the element is the ignitor right? The trick here is the ignitor, if it's a glow type. The ignitor must decrease it's resistance enough to allow the gas valve to receive it's calibrated min current to open. If the ignitor is bad it can glow just fine but if the intensity is not sufficient, the resistance will not be decreased enough to trigger the gas valve. Sorry to get complicated. I would replace the ignitor first and go from there. Hope this helps.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Frigidaire FEB27S5A Electric Single Oven
The Glow Plug is glowing, but oven will not light up.
This may sound strange but it is most often the glow plug that is bad. What happens is as the ignitor (glow plug) ages the resistance internally rises, this rise gets to a point where it limits the electrical current just enough that the valve no longer opens.
May 05, 2010 | Electrolux Ovens
Igniter comes on but gas won't light
It should glow almost a bright white. If its just an orange glow then replace the ignitor. Its probably just weak. If its weak it will not allow enough current to flow through it to open the gas valve. Good luck _MJ_
Mar 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Slow oven lighting....bakes for 20 minutes than stops heating
Hi, The oven should ignite within 20 to 30 seconds. The most common problem is that the ignitor gets weak and will not open the gas valve like it should. This would be my first part to change.
May 09, 2009 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
503 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
