The screen goes blank. At boot-up the image is dark and soon is lost. The screen is blank. I used another monitor and the computer and screen work fine. Problem is with the Princeton VL2018W monitor.
Please restart your computer and tap the F8 key as soon as you see something on the screen. You should get the advanced boot menu. Select Safe Mode from the list.
Let me know if you were able to boot to safe mode.
Then your system configuration and the Operating System are not supporting each other. OR If you can arrange one more monitor, try connecting it and see whether even then it goes blank. If not then the previous monitor has some problem.
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
First you'll have to power off the system.
Please power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
The computer will go to the system setup. Check if the screen goes blank here.
If the screen stays on then try this.
1. Please power off the system.
2. Please power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll reach the Windows Advanced Boot Options Menu on the screen.
3.Select Safe mode with Networking.
4. Select Administrator at the log in screen.
5. Warning dialog box with the message Windows is running in safe mode. appears. Click the Yes button.
6. The desktop appears with the words Safe Mode appearing in all four corners.
7. Uninstall the video drivers and restart the computer.
8. Resintall the video drivers.
PETTY SOON YOU WILL NEED A NEW MONITOR, IT PROBLY IS NOT WORTH FIXING,
TAKE IT TO A TV SHOP AND LET THEM LOOK AT IT, THEY CAN TELL YOU IF IT IS WORTH FIXING
Hi this is the way how to examine what's wrong with your LCD
monitors. Power on both CPU and monitor. After the scree goes dark, you
check that you can see the image on the screen by shining a flashlight into the
screen, not directly but find the best angle to the screen and take a look very
closely. If you can see the icons or any image, there will be a minor problem.
Like me, I can see window image using flashlight and check lamps inside. Some
of them were broken and it is easily replaced. If you cannot see anything on
the screen, there'll be some problems with inverter board. If you have
soldering tool and want to fix it by yourself, check the caps first. It may
cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
Ok, from the beginning. Can you do a cold boot and get into the bios? (is there an image on the screen then)
Secondly, can you connect to an external monitor and see an image?
Did it do this only when it was heading in to hibernation? If so, it sounds like the power management needs some adjustment.
If there's no image on the external monitor, you may have a video/motherboard problem, or it still could be the operating system/power management.
It all depends on if you have video in bios.
Let me know.
Good luck
screen goes dark
I tried the moniter in a different pc with the same result.
i think there might be problem in monitor adjustment.
2 if it is ok then the problem in video section.
3 also check for loose connector
4 crt base might be loose.
It could also be that the video card is not compatible with this monitor. After the pc boots up, can you get into windows? Does the monitor always go out at a specific time on boot? Say for example; you boot the pc, windows startup splash screen comes on; screen does a quick flash and goes blank. Then it maybe the BIOS setting for the video. Try changing the IRQ setting. You could also try putting the video card in another slot. Do you have the manual for the motherboard?
Ray
