We have a Norstat Meridian M7310 phone system - is
We have a Norstar Meridian M7310 phone system - is there a way to put a general greeting on before the line rings into the receptionist? One that might be used for holiday closures for example?
Yes, that is correct, we have a Norstar system, w/ M7310 and M7324 phones. This may or may not be helpful but I will tell you what we currently have since no one here really seems to know what we have.......ugghhh. We have 4 lines that ring into our main phone number and we have voicemail set up, but we do not have a receptionist line or any formal routing system. When all 4 lines are busy it rings into our back line and that goes into a Qwest voicemail. Does this help?Yes, that is correct, we have a Norstar system, w/ M7310 and M7324 phones. This may or may not be helpful but I will tell you what we currently have since no one here really seems to know what we have.......ugghhh.
No you don't have a m7310 phone system > The m7310 is a phone for a norstar phone system and if you have a voice mail system associate with the norstar system you can program a message and set the number of ring for each line which is attached to the norstar so it goes to vmail before the receptionist. You have to give us move info to help you.No you don't have a m7310 phone system > The m7310 is a phone for a norstar phone system and if you have a voice mail system associate with the norstar system you can program a message and set the number of ring for each line which is attached to the norstar so it goes to vmail before the receptionist. You have to give us move info to help you.
Re: We have a Norstat Meridian M7310 phone system - is
THE PHONE IN THE BACK IS THIS A NORSTAR PHONE. WHAT IS THE QWEST VMAIL AND WHAT DOES THE NORSTAR SYSTEM LOOK LIKE . SOUNDS TO ME THAT QWEST IS SUPPLING VMAIL AND NOT YOU OWEN NORSTAR COULD YOU CLARIFY THIS FOR ME.
Depends on which system you have. M7310 is just the phone model which is compatible with all norstar meridian systems.
The easiest way (which only works on one of the phone system models) is to dial Feature ** TIME and use 23646 as the password. If feature **TIME doesn't work for you, it might be best to do it with someone over the telephone since it can be slightly tricky.
I need to chane the main greeeting on the Norstar T7316E and the message that lets you go to different people mail boxes, it is already programmed , but I would like to change it, Thanks
D [email protected]
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting either 2 or 4 (you might want to listen to the greeting first). press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
ok then the log in should be something like 1020000...
there is a way to reset the system password...
Ok there are a coupleof steps:
1. feature 985
2. The Call Pilot DN is displayed... now dial 9
3. Pswrd: RESETSMPSWD (73738767793)
4. RESET PSWD? Press YES. Login will be changed to default (1020000)
first press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
do you have voice mail with your norstar system
