Question about Olympus Camedia C-450 Zoom Digital Camera
When I go to take pics a window comes up saying Card Setup w/ power off and format choices. When I choose format it lets me choose yes: caution erasing all, then Card error comes us. What do I do now?
Posted by klr1844 on
Anonymous
    President:
  • 1,566 Answers
How long have you had this memory card? What you can do is to try and format it first using your computer. And then reformat it again using the camera.
To format from your computer, you should a memory card reader so that you can access the card. After the usual device detection process, locate the drive and then for Windows users, right click it and then hit Format. Accept the default settings but do not forget to check Quick Format. Let the process finish. And then proceed with the formatting process on your camera.
Posted on Dec 17, 2009
Just bought the Nikon S01 camera. Charged it completely, turned it on, completed setup, took a few pics. Then when I turned it off and back on, it says "Card is not formatted. Format card?" If I select...
Save the pictures you have taken to your computer, and then choose the Format Card option. You have to Format the Card to make your camera work. If this does not work, contact the Camera's company web site and ask them for advice
1helpful
When I turn on my Kodak Easyshare it says "Internal memorys is full." The lcd will show what I'm looking at but I am unable to do ANYTHING!! can't delete, take picture, change mode..etc. help please.
You need to go into the menu and look for "Format Memory Card" or something close to that. It will usuall ask: Do you want to format...? Choose yes and all will be erased. CAUTION: Make sure you save your pics to your computer before formating the memory card. Let me know if you need further help.
When camera card is displaying full, how to I access pics to delete and make more room?
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card and it can be used again.
3helpful
When I go to take a pic, it won't let me because it says "write protect"
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
9helpful
My camera says write protect and won't let me take pics
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Can't make any photo or preview
CAN'T EDIT OR MAKE ANY PICS
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect image and the card can be used again.
Weres my pictures!
if you select yes then all pictures will be deleted, and you cannot retrieved all pictures anymore
sorry about that
Formatting what?
I hate to sau it but the reformating process does delete all files on the card. If you have either a xd slot on your pc (MAC) try to off load or make copies, Then follow the formatting directions in the owners manual. Good Luck
Olympus Camedia C-450 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
