Panasonic DMR-EZ48VEB When i play a vhs tape the picture is fine ,but as soon as i try to record the picture onto a disc a black line about 1 1/2 inch appears across the bottom of the screen??? HELP
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
If the disc playes back then the problem is not with the DVD unit. In order to record white noise, the channel selected for record is probably not tuned in. Try recording the same channel on to video tape and see what results you get.
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
If you have another VCR system (Master) you can connect it from the master to the Panasonic DMR ES15 (slave). Insert the copyrighted tape onto the master VCR system and insert a empty VHS tape on the slave system. In the slave, record from the master. When done, you can record from the videotape you have made from the master tape, to the DVD recorder.
If you still have problems, please contact the manufacturer of this model.
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
