Can't upload pics to mac book with recently installed snow leopard operating system. I have image capture, but it doesn't work with camera? Do I need a newer version of image capture or what? Help!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the <a href="http://www.amazon.com/Apple-MC581Z-A-Mac-10-6-3/dp/B002I0JKE2">10.6 Box Set</a>.<br />
<br />
<span style="font-weight: bold;">System Requirements to run Snow Leopard:</span><br />
<ul>
<li>Mac computer with an Intel processor</li>
<li>1GB of memory</li>
<li>5GB of available disk space</li>
<li>DVD drive for installation</li></ul>
<span style="font-weight: bold;">Snow Leopard Installation Instructions:</span><br />
<ol>
<li>Just insert the DVD in the optical drive.</li>
<li>Restart your Mac while holding down the C key.</li>
<li>You will be guided through the installation procedure and be prompted at one point to choose which install option you want.</li>
<li>Once the Snow Leopard install is completed the Mac will restart itself.</li>
<li>You will probably be asked to register with Apple upon restart.</li>
<li>Enjoy Snow Leopard on your Mac!</li></ol>
<b>Q: Can I upgrade directly from Mac OS X 10.4 (Tiger)?</b><br />
<br />
<i>A: Yes. Apple recommends purchasing the Mac Boxed Set for this
purpose, which will also update iLife (it is unknown at the time of this
writing whether older versions of iLife work with Snow Leopard) and
iWork. Also note that while it has been said that the $29 upgrade will
work with 10.4, it is not officially supported and may be in violation
of the licensing terms.</i><br />
<br />
<b>Q: What happened to the different install options? Can't I do an Archive & Install?</b><br />
<br />
<i>A: Apple has revamped the familiar installation options for Mac OS X.
You now have two choices, either a straight upgrade or a clean
install. Supposedly if you choose to do a straight upgrade, what
actually goes on behind the scenes is what was traditionally known as an
Archive & Install.</i><br />
<br />
<b>Q: Is there anything I can do to better prepare myself for the upgrade?</b><br />
<br />
<i>A: Yes. It is advisable to run a Verify/Repair Permissions and
Verify/Repair Disk in Disk Utility. You may also want to run the
maintenance tasks in <a href="http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html">Onyx</a>. And finally, it would be wise to get your applications up to date using a program like <a href="http://metaquark.de/appfresh/">AppFresh</a>.</i>
Click here to download iPhoto 8.1
Double-click the .DMG file to open it up. Another new icon with a name similar to the .DMG file will appear on your desktop
You will need some install disks to even begin working on your issue.
Your options:
Find someone with the same model MacBook Pro and borrow the disks.
Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
Check eBay for install disks but make sure they are for the same model MacBook Pro.
Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use iPhoto or any other photo cataloging program.
Hi, You will have to give me more details regarding the "Perfection 300" you are mentioning about. Please provide the full model no. along with the manufacturer name. In the meantime to have you work on with your scanner, please click on the link below to get drivers for Epson 1600 which are compatible with MAC OS. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14577&prodoid=8864&infoType=Downloads&platform=Macintosh After you click on download now, on the next page you can simply select the radio button: No thanks, I prefer not to receive this information. And click on accept to get your drivers. You should be good to go for now with one of your scanners. I will be awaiting the complete information from you regarding “perfection300” Please let me know if the provided information has been helpful. Please rate me if the information provided was able to help you.
The type of printer/scanner you have (HP, Canon, Lexmark, etc) and the operating system installed on the Mac.
You can find the operating system number by clicking on the Apple Menu (top left corner of the screen) and pressing "About This Mac". In the center of this window it will say "version 10.5.8 or 10.6.2 or 10.something)".
If it's 10.5.8 - that means you are running Leopard, and you may have to download updated printer drivers from the maker of your printer.
If it's 10.6 - update to 10.6.2 (apple menu > software update).
If it's 10.6.2 - restart the computer and disconnect the scanner. Restart it and connect it. Snow Leopard should discover the correct drivers automatically.
After that, all scanning is done in the Image Capture.app (located within Applications > Utilities.
