Question about Konica Minolta DiMAGE S414 Digital Camera
I am using the Minolta Diamge S414 and when I put the memory card in it says unable to read card. The card is a Sandisk 4GB Extreme. Is this card not compatiable with the camera. Thanks
    New Friend:
  • 55 Answers
Try to format the card first. Sometimes, if there is data on the card, the camera will not be able to read it. You should always format memory cards on the camera that they will be used on.
Posted on Dec 17, 2009
WHAT 2GB BRAND SHOULD I USE FOR MY MINOLTA DIMAGE S414 CAMERA
Any brand will do, but use only old type 2GB SD cards, no SDHC types.
I would recommend Transcend, Kingston or Sandisk, etc.
Dec 28, 2010 | Konica Minolta DiMAGE S414 Digital Camera
Somehow we locked our Sandisk Extreme SD HC 4gb card. And now when we put it in the camera, it says card locked. Can anybody help how to unlock it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 03, 2010 | SanDisk Extreme III 4GB Secure Digital...
I just purchased a 4GB SanDisk Extreme lll CompactFlash for my camers but when I try to use it I get the Unable to use card message. What can I do?
I suspect 2GB is the maximum the camera will take. A 2GB Sandisk card works in my 7i. When the DiMAGE 7i was launched, 256mB was about as big as CF cards got!
Sep 06, 2010 | Konica Minolta DiMAGE 7i Digital Camera
Minolta dimage s414 camera, error no card try to use a 4 gb flashcard and then it read unable to use card.
The S414 was designed to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it will not work. You need to stay with SD cards, 2GB and smaller.
Jul 11, 2010 | Konica Minolta DiMAGE S414 Digital Camera
SanDisk Extreme III 4GB, unable to retrieve the 500 images on it.
SanDisk Extreme cards are supposed to ship with RecoveryPro software which should help you get the photos back. If the software is not on your card you may be able to get it from their website or another SanDisk card.
Mar 27, 2010 | Cameras
Sandisk extreme iii 4gb problems??
May be a problem or trash in the reader slot.
Try the card in another device connected by usb, ie, put it in a camera then connect it to the computer.
Dec 17, 2009 | SanDisk Extreme III 4GB Secure Digital...
SanDisk ImageMate 12in1 cannot read SCHC 4GB or higher cards
Correct!!!! This card reader cannot address cards that are higher then 3gig and cannot read sdhc cards. Most older readers will not be able to read the HC type card, and by older I mean if its 6 months old or more. To read these cards you need to purchase a new card reader. I know, My camera uses 4gig cards and I was unable to access the pics until I bought a new reader..
Dec 02, 2009 | Computers & Internet
I have Sandisk Extreme III 4GB memory card why after i shooting photo the file is cannot read?
Make sure your camera is compatible with a 4GB flash card. Some only take 1 or 2 GB cards. If that isn't the issue, format your card inside the camera with the camera's format utility.
Oct 08, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Minolta Dimage S414 camera doesn't like a new 4GB CF card
Check your manual to see if your camera accepts a card that large.
Aug 30, 2009 | Konica Minolta DiMAGE S414 Digital Camera
Sandisk 4gb memory card w/adapters
oh! too sorry for that..you have formatted your card and you cannot put the files back.. but after you have formatted it is the problem had been solved?
Feb 23, 2008 | SanDisk Memory Media
Konica Minolta DiMAGE S414 Digital Camera Logo
185 people viewed this question
Top Konica Minolta Cameras Experts
Ekse
 Larry
Larry
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
