Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Picture going black but audio still on
I have a Samsung HLN5065WX/XAA
Symptoms: Picture blacks out but I have audio. Lamp is on in the back and I can't bring up the menu in any source (DVD/Cable/etc...). I have to turn off the TV and wait for the lamp to shutoff and then turn on the TV to get the picture back. This happens intermittently but frequently and sometimes it stays on for a while before it blacks out.
Any Ideas??
Posted by daniel_dinge on
Arnel
    Sergeant:
  • 184 Answers
DMD module causing the problem
Posted on Dec 24, 2009
Ness
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 128 Answers
Yes this could be a board issue
Posted on Dec 19, 2009
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have no color on my samsung hln5065wx/xaa DLP tv. Is it my color wheel or bulb ?
If it is just no color but you still have a picture it should be your digital board. This is the board that mounts behind the light engine and should be encased in a shilver colored metal sheild
Aug 13, 2009 | Samsung Televison & Video
Samsung model HLN5065WX / XAA
You need a new color wheel. Go to www.samsung.com and do some searches. I had to have someone come out and replace mine.
Sep 06, 2008 | Proton MM2701VT 27" TV
Samsung DLP HLN5065WX/XAA
krugie, get it replaced now or the lamp will burn up, be advised that they are expensive to get replaced, not an easy job to do, fix it now or pay much more later is the best advice I can give you, good luck, BMW Rider
Dec 28, 2007 | Samsung HLN437W 43" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
394 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
