Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
I just bought a bissell power roller prodry cleaner and turned it on and nothing happens. Is there another button I am not turning on to get it to work?
Posted by maagsie67 on
Anonymous
    New Friend:
  • 85 Answers
The power switch is on the back of the handle. If that dosen't turn the unit on take the handle off and put it back on make sure its tight. If still nothing then its defective. Bissell says not to return it to the store contact a service center. If you have never used it return it.
Posted on Dec 16, 2009
Why is the tool attachment not working
Check for kinks in the hose. Unwind the hose all the way and depress the sprayer button. Check the filters for clogging (listed in your User's Guide) Call Bissell Consumer Care at 1-800-237-7691 Hope that helped.
Aug 23, 2014 | Bissell 7350 PROdry Upright Steam Cleaner
Lost manual
Hi Carole. You can easily download a copy of the user guide by clicking on the following link, then entering your model number in the box.
http://www.bissell.com/user-guides/?cid=ccsocial
Mar 26, 2013 | Bissell 7350 PROdry Upright Steam Cleaner
How do I replace the roller?
Remove the six screws from the bottom of the machine, remove the belt cover, and slide the brush out.
Here's a link to the downloading the user guide.
Nov 24, 2012 | Bissell 7350 PROdry Upright Steam Cleaner
I have the 7350 prodry carpet cleaner and it while cleaning a room today it completely shut off with no rhyme or reason.
It has a build in clog protector. Once the machine starts to overheat due to a clog, it should shut off to prevent burn out. Unplug the unit, Make sure there are no clogs, sometimes even the smallest clog does not seem major but remove them. Also, make sure cannesters are all connected proper and tight. Good luck!
Mar 26, 2011 | Bissell 7350 PROdry Upright Steam Cleaner
I do not have a problem, other than i cannot find my manual for the bissel prodry and I want to shampoo my carpet. i need instructions on how to use it.
You can view and download the instruction manual in PDF format by clicking this link.
For additional details, click here
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Aug 01, 2010 | Bissell 7350 PROdry Upright Steam Cleaner
Switched off mid cleaning
Unplug from power and remove the screws from the back of the upright handle - slide the handle back to remove. look for the wire that came off the connector. probably right at the power switch. Hope it helps.
Apr 08, 2010 | Bissell 7350 PROdry Upright Steam Cleaner
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
171 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
