Question about Prima C2012 TV
I need 3 digit code for my Prima tv to program bell express vu
I need a 3 digit code for my Prima tv to program Bell Express Vu remote
Thanks
Posted by rs33properti on
Anonymous
    New Friend:
  • 5 Answers
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Posted on Aug 23, 2010
sharifah_200
    New Friend:
3 Related Answers
Anonymous
SOURCE: PRIMA TV CODES
The 4-digit RCA code is 1238 if using an older RCA universal remote, or just 238 for the newer 3-digit ones.
Posted on Sep 28, 2008
Colin Bett
  • 65 Answers
SOURCE: universal remote prima tv code
Codes are 0062,0039,0294,0442,1299,1537. Ted10
Posted on Apr 16, 2009
Anonymous
SOURCE: I am having problems programing a universal remote
urc-386-remote.blogspot com
URC-386 HRS-GLOBAL
URC-386 Universal Remote Control
http://urc-386-remote.blogspot.com
Posted on Feb 03, 2010
I need remote codes for express vu remote fo my Hisense 22' TV
Try the following remote codes:
748
759
178
10019
505
627
Mar 21, 2009 | Bell Televison & Video
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Need codes for bell express vu satellite for innovage products jumbo remote
Press and hold tv until red light flash , press code search , press channel up until the tv goes off , then press record and your done
Feb 10, 2009 | Big Button TV Universal Remote
Bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
Need codes for jumbo universal remote for phillips tv and bell express vu
Press the tv and hold it until the red light flash , then press code search , press channel up until your tv goes off , press record and that it your done . Will work for your tv but maybe not for the express vu receiver , this way of finding code makes the remote trying them all so if it dont work on your express vu remote , no other codes will .
Dec 08, 2008 | 2006 Honda ANF125 Innova
Jensen JR400 remote codes
My sheet says the code for a Sony TV is:0000
What an interesting number... Hope it works for you. :)
Apr 12, 2008 | Jensen JR400 Remote Control
Home Theartes
Trying to program Toshiba remote CT90157 to work with my Koss KS-5116-2 DVD player... any suggestions ???????
Jan 12, 2008 | Televison & Video
Prima C2012 TV Logo
2,872 people viewed this question
Top Prima Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
