We have a Wordsmith 100. When typing the w, r, t, y i, o, d, f, g, k, ", x, c,v, b, n, ;, / keys a symbol is typed which appears to be a combination of an enlongated { and a comma. Any ideas what is causing this?
Posted by pamb450 on
Anonymous
  • 328 Answers
Do you have a different printwhel to try? Also, make sure you have not activated any odd features by using the mode or features keys on the keyboard.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Dec 30, 2009
How to type @ symbol
I am not familiar with this particular keyboard, but it sounds like you are not finding that symbol (@) on the keyboard. On most keyboards it seems to be the shift of the "2" key (at the top of the keyboard, not on a separate number keypad). I checked keyboards from three manufacturers, and that was the case on all three. However, if that key is not working properly, you could define "(a)" or something similar to be auto-corrected to the "@" symbol. Finally, you could try typing the ASCII character by a keystroke combination such as Alt-0064. In MS Word, when I type that combination (make sure to use the numeric keypad, not the number row keys), I get the "@" symbol. The same works in many programs.
Jan 17, 2014 | Logitech Wireless K400R 79 Key Slim...
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
My smith corona model ka11 is typing symbols instead of the letters. Can you help me get this corrected?
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. If not try it again.Check to make sure no pedals on the printwheel are bent.
Hopes this helps!
Feb 10, 2011 | Smith Corona Wordsmith 100 Typewriter
How do you change the pitch or size of the type? The typewriter has 3 pitch settings, but we cannot figure out how to make the adjustment.
hold down "code" key and press 6 for 10 pitch. "code" key and press 7 for 12 pitch. "code" key and press 8 for 15 pitch. to change type size or style you have to replace the daisy wheel.
Nov 10, 2009 | Smith Corona Wordsmith 100 Typewriter
Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Jan 14, 2009 | Smith Corona Wordsmith 100 Typewriter
How do I adjust margins on Smith Corona WordSmith 100?
Return to the L. margin Press code and 1 release kets backspace to where you want L. margin press L mar key.
DickyO
Jan 06, 2009 | Smith Corona Wordsmith 100 Typewriter
Corona smith premiere 100 typed writer
El problema de tu Maquina es que tiene un Censor de Cubierta Abierta en la esquina de carro impresor lado izquierdo y esto no esta conectado o no lo esta oprimiendo la cubierta cunado la cierras , revisa esa area
Apr 22, 2008 | Smith Corona Wordsmith 200 Typewriter
Typing problems
Please give a make and model.
DickyO
Mar 11, 2008 | Smith Corona Wordsmith 100 Typewriter
Marvin
Marvin
