Question about Kenmore HE2 Plus Front Load Washer
Kenmore (HE2PLUS) front-loading washer leaking out the front door,,,,,,,,C. Pellecer
Anonymous
    Sergeant:
    Champion:
  • 382 Answers
Check the inner door seal it may be damaged that may be why it is leaking
Posted on Dec 17, 2009
We are seeing F24 for the first time today on our Kenmore HE2plus front loading washer. What does it mean? How do I solve it?
Hi
F24 is a water temperature sensor error. You have to unplug the washer and check the water temperature sensor and its connections, if that is fine then check the resistance of the heating element and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore HE2 Plus Front Load Washer
He2plus from Kenmore....washing machine door will not unlock...even after unplugging..washer is empty
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 07, 2010 | Kenmore HE2 Plus Front Load Washer
I need to replace the door gasket on my HE2Plus -
Its not too hard depending on your level of dig i say its a 8/10 job...try utube for video on how to do ..
Apr 19, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer (HE2Plus)
check to see if you still have a warranty on the washer other than that check the inner door seal if worn or crimped try to fix or replace it
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
What is code f21 on kenmore he2plus washer and how do i fix it
It means you have a drain problem. It could be a pressure switch or the drain filter plugged.
Jul 14, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer he2plus
My HE2 Plus vibrates terrible. Moves all over the place. Anyone else with this problem
Jan 24, 2008 | Kenmore 46462 Front Load Washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
