Question about Canon Rebel XT / EOS 350D Digital Camera
Will not take pictures
In basic mode when I push the shutter button a busy signal flashes followed by different numbers and no picture is ever taken. If I turn my focus to manual focus the camera works but it does not work in auto focus.
Posted by barnabasjc on
Arun John
  • 281 Answers
Does your lens try to focus or it doesn't try at all? You will have to understand that for the camera to autofocus successfully, theere should be adequate light and contrast. That means, autofocus often fail to focus even colored walls or objects under dim light. If you tried all this in daylight, outdoors, then the autofocus sensor is faulty. Please reply with details of how you tried the af.
Posted on Dec 21, 2009
Cannon EOS500D, taking a picture in creative modes I have to press the shutter button twice to take a picture.(not counting the half pressing of the shutter button. the second pressing of the shutter...
Hi kevinmullen8 - was this ever resolved? My mum was mucking around with my camera (eos1000d) and I have the exact same problem (press shutter twice in creative mode). Factory reset was of no assistance.
Please help!!!
5helpful
Screen is black when turned on. view side works great on old pictures when button is pushed it flashes ,but no picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
3helpful
2answers
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
1helpful
Black Screen and takes blank pictures
It sounds like a stuck shutter. As the camera is less than a year old, Nikon should fix this for you for free under warranty. Contact them.
For others that experience this with cameras that are out of warranty:
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Getting "busy" display on all modes except no-flash mode...
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
"busy" in all modes except non-flash setting on 300d
bad memory card most likely.
try reformatting card in camera.
try battery out for 10 seconds for full reset if that does not work.
may have a problem writing to card.
you can also try another card. cf i believe on that camera.
good luck.
mark
1helpful
Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
