Question about RTO Ho Herpa Freightliner Truck Tractor
Active faults 1 at startup screen
I have Freightliner trucks and It's show ''Active Faults 1'' at startup screen. What's does it mean?
Posted by thaibaminh on
Anonymous
    New Friend:
  • 4 Answers
If you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Posted on Apr 27, 2010
  • Henry Bodle Aug 06, 2013
    Where is the mode button on a 2008 Freightliner?
Donnie Wilson
    President:
  • 986 Answers
You need to pull codes ,it can be the engine or abs or on the freightliner side
Posted on Dec 25, 2009
Will a 2002 freightliner century classic hood fit a 2003 freightliner century classic
Better ask Freightliner.
Freightliner CENTURY CLASS 120 Hood Parts ' TPI
truckpartsinventory.com > Hoods > Freightliner
Freightliner Century Class C120 BBC Fiberglass Hood Shell. Fits Models from 1997-2002 with Old.. ... Shell (Economy). Fits 2002 - 2004 Models with New.
Search Results Freightliner CENTURY CLASS 120 Hood on ...
https://www.heavytruckparts.net/search.php?...FREIGHTLINER...CENT...
Active Truck Parts Hood FREIGHTLINER CENTURY CLASS 120. More Info ... HoodFREIGHTLINER CST120 CENTURY, 2002, 1FUJBBCG92LJ79765, Hood
Oct 30, 2015 | Cars & Trucks
2014 freightliner cascadia, dd13 showing an active code mil light Diag, says ecu 01 , what can that be
the code dd13 for a detroit series 60 refers to coolant level sensor ---input voltage low
should be in the radiator top tank and energizers when the coolant level in the cooling system falls below a set point in the radiator
contact a service dealer for a diagnosis and information as to the fix.
Sep 05, 2015 | Cars & Trucks
Where can I find what the fault lites mean. on the dash of a Cascadia w/dd15
http://www.thetruckersreport.com/truckingindustryforum/freightliner-forum/240942-2010-cascadia-w-dd15-active-fault.html
Jan 06, 2015 | Cars & Trucks
I have a Freightliner 2006 A default code is showing up That code is 25 Can you help me figure it out
code 25 says its a clutch slip. it might very well mean that your clutch is slipping or starting to show signs of slippage. have it replaced by a certified mechanic.
Jun 04, 2014 | Cars & Trucks
Engine Faults on a 2009 Volvo VNL670 w/ a Cummins ISX
i have a 2009 volvo 670 automatic transmission. i have a fault code for the transmission. RANGE LOW ACTUATOR
( VALR )
ELECTRICAL FAULT
INACTIVE.
does anyone what those codes mean?
May 03, 2013 | 2005 Volvo XC90
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
Fix revers in automatic Freightliner Truck
Which transmission you got. Zf meritor or ultrashift?
Feb 19, 2010 | RTO Ho Herpa Freightliner Truck Tractor
Acer Aspire blank screen
yes its a virus that's blocking explorer
a complete clean xp installation is needed to fix this problem.
rate plz
Mar 09, 2009 | Acer Aspire 5315 Notebook
RTO Ho Herpa Freightliner Truck Tractor Logo
8,583 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
