Get rid of all data that you no longer need or apps you never use. The space warning means that the download exceeds the memory capacity of whatever you have left free, downloads are not sent to the SD card so that doesn't come into play as far as available storage goes on this device.
The internal memory cards of some Android devices are partitioned for app storage and installation. Some of them have partitions that are quite small such as one Gigabyte or smaller. The remainder of the storage cannot be used for apps.
If it keeps saying not enough memory space then chances are the app partition is full. The only way to free up some space is to uninstall some apps that are stored there but not being used. You can see which apps can be uninstalled in Settings > Apps and look at them one by one to see if an uninstall option is listed. Simply click *uninstall* to remove them from the app storage partition. This will free up some extra space for some new apps or for updates to older apps you still like and use.
Also some of the apps might show an option to move them to an external SD card (if your device has a slot for one and if an SD card in inserted therein). Do move any and all to the external SD card of you have that option as that will also free up that space from the internal SD card.
Not Enough Memory error suggests that you dont have enough space to load the program into the Memory. Check Phone's Memory (It is about 30 MB total) if there is stuff in Phone's Memory then shift it over to Memory Card and cleanup the space in Phone's Memory. It will definitely resolve this issue. If even after wiping stuff from Phone's Memory doesn't work, reset the phone.
maybe the free space you are pertaining to is the phone memory. if you have a memory card in your n70 device. go to menu navigate messaging press the options and then choose other settings. Under "memory in use" change it to Memory Card or vice versa and check if the problem still persists
Ilyas,
It is not the memory card but the memory. It means that there is not enough RAM on the phone to run that program. The memory card is the storage space while the RAM is the working space. Two different spaces altogether.
Try and close some of the other programs that you may be running in the background. That will free up some RAM and the program in question may run.
Check the amount of free space on your phone.. If it does have free space and still its acting up then it may be due to either of these problems.. 1)Memory card and Phone memory corrupted. Solution: Format both Phone and Card memory. If doesn't work try getting another memory card. 2)Firmware issue: The phone's firmware is partly corrupted. You can go for a firmware upgrade. Hope this helps!
