Question about Sumvision Audio Players & Recorders
I have a cyclone media player thar once loaded with movie files will not recognise then when in tv mode.The files have been placed in the movie folder and are there and can be played via a pc.The only files it will recognise are video TS files but not AVI and others iy is supposed to be able to play.The unit has been returned to the supplier several times and now a new one has been supplied which has this problem. Stephen Parsons
Posted by stevesalp on
Anonymous
    New Friend:
Format with fat 32 make 3 new folders movies music photo drag folders into relavent folders this should cure the problem
Posted on Mar 07, 2010
7helpful
Iomega screenplay firmware
you dont't update firmware. screen play dx latest firmware lot of bugs and not respond remote controller after 30min playable movie.
tip
Enjoy/watch Blu-ray movies on HDTV via WD TV Want to find a solution to playback...
Want to find a solution to playback Blu-ray movies on your widescreen TV via WD HD Media Player? As a matter of fact, WD TV HD Media Player promises to play just about any video format you throw at it, including high definition video up to 1080p. You put the videos on any USB mass storage device, like an external hard drive or a thumb drive, and plug it into the device, WD TV HD Media Player will recognize the files on the drive and play any video, audio, or photo files it finds. However, according to the feedback provided by some users, WD TV HD Media Player does play m2ts selectively only, some are, and some are not. In purpose of solving this problem, this post will talk about how to rip Blu-ray movies to USB for playback on TV via WD TV HD Media Player.
WD TV HD Media Player supported file formats:
Video: MPEG1/2/4, WMV9, AVI (MPEG4, Xvid, AVC), H.264, MKV, MOV (MPEG4, H.264), Subtitle SRT (UTF-8)
Audio: MP3, WMA, OGG, WAV/PCM/LPCM, AAC, FLAC, Dolby Digital, AIF/AIFF, MKA Playlist PLS, M3U, WPL
Photo: JPEG, GIF, TIF/TIFF, BMP, PNG
Now let’s have a look at its operation steps.
Choose MKV format, how to rip Blu-ray to MKV?
Step 1
Download, install and run this Blu-ray ripping software
After launched it, you will see the following interface at once. There are three ways provided to import Blu-ray files, namely through clicking on "DVD Rom", "DVD Folder", and "IFO/ISO".
Step 2
Load the Blu-ray disc.
Click on the “DVD Rom” button to import Blu-ray movie from the disc, or click on “DVD Folder” button and browse to your target files. It takes a few seconds to load the whole movie, so be patient. A view log will pop up when loading process completes, you can simply click "OK" to confirm or press Ctrl+O to close it. Now all the M2TS files in file list are checked, right-click and choose "Uncheck All". What you need is the main movie---the one with longest duration. Check it and leave unwanted M2TS files unchecked. You can rename the output file by clicking on the file name in Destination File column. Right below the file list you could find "Subtitle" and "Audio" droplist, where you can set output subtitles and dubbings to the languages you like.
Step 3
Click on Format bar, select “Common Video” from the format list and in submenu you could find MKV video format. If you would like to maintain best quality, just back to the format list and move down your mouse to point at “HD Video”, here you can find “MKV HD Video”. Check it and hit on the small folder icon to specify an output folder. Then click “Settings” and customize advanced audio and video parameters. For instance, you may set Video to 1920*1080p (to fit for the wide screen), 25mbps, 30fps, and Audio to AC3/AAC codec, 192kbps, 5.1 channels. Click "OK" to confirm your settings.
Step 4. Start conversion.
Click on the “Convert” button and the program will rip Blu-ray movies to MKV video format for you very soon. You could set auto shutdown in progress window (it pops up once you click Convert) or leave it there and come back later (the ripper will tell you how long it takes). Enjoy the converted MKV videos!
Once finished, you can get the generated files for WD TV via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your Blu-rays.
That's all, Enjoy it!
1helpful
Cant play video
1. Turn on the MP3 player, go to Settings/Setup - System - Change USB mode to MSC
2. Connect the MP3 player to the computer
3. The MP3 player will show up as a Removable Disk drive under 'My Computer'
4. Double click on it, it will load Coby Media Manager, follow prompts to install
5. Click the 'Movie' tab at the left hand side of Coby Media Manager, the software will scan your computer for video files.
6. Once your video shows, right click the video, and click 'Sync', this will add the video file to your MP705 with the correct format.
If you need the Coby Media Manager:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0924.exe
1helpful
2answers
I ripped Bluray movies using "ANY DVD HD" to my hardrive then playing them through "WD TV Live HD Media Player" (using HDMI cable to Sony Bravia HD L.C.D.TV) some movies work good but others play the video...
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
2answers
I cant load videos or music on my GPX ML658B Audio player
Video
Video files must be .AMV formatted to work on this MP3 player. Below is a link to an amazing converter. It’s FREE and will convert your entire file.
http://in.answers.yahoo.com/question/index?qid=20070610062401AAZXp2P
Once you have the video files formatted to .AMV
  1. plug your MP3 player into the computer
  2. Go to MY COMPUTER.
  3. Find your .AMV VIDEO
  4. Drag file to the Scroll Bar on the left, hold the file over the GPX DEVICE
  5. Two folders will appear under it. Put file into ALBUMS
To then access videos put onto the device. Hold the MODE BUTTON on your MP3 player until you are returned to your menu screen. Scroll to MOVIES and your videos will be there. :D To return to listening to music or looking at Pictures, hold the MODE BUTTON and simply select your desired destination.
This player requires Windows Media Player 11 to transfer music files.
I can't down load videos and movies on my gpx
  2. Go to MY COMPUTER, you should see a scroll bar on the left.
  4. Drag file to the Scroll Bar, hold the file over the GPX DEVICE
1helpful
2answers
Movies and Pictures to my GPX mp3 ML638B
The GPX ML638B takes only AMV files for video. you have to use the utilities tool that comes with it to convert video files. or find one online if you prefer. also you can download pre exsisting AMV format movies to load into it.
just be sure its in a USB mode and load directly onto the 1st area when you open its designated drive location. as for Mp3's no conversion is needed. simply load em onto the device. remember. video and pictures requre it to be set in USB mode (mode button on its side) and music out of USB mode.
while plugged into the PC on its screen will show USb on lower left of screen when its in usb mode. and wont show if its out of it.
Top Sumvision Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
